Waggy 44 into tj/yj - Page 4 - JeepForum.com
post #46 of 90 Old 02-01-2009, 09:11 PM
Air Sierra
Air Sierra's Avatar
I'm running waggy 44's front and rear with 5.38s Detroit rear and true trac front, on 37" tires. Works great, with moser shafts.
But I have ripped teeth of my rear pinion twice but I think it was due to the gear brand.
YES My old jeep is RUNNING A 2.4L TURBO MOTOR If you want to know
Air Sierra is offline
post #47 of 90 Old 02-01-2009, 09:19 PM Thread Starter
Solidkm
you also have a turbo lurking in your engine compartment. i recognized your name from another forum. thumbs up.
is this what i need then...
http://www.4x4groupbuy.com/store/yuk...ts-p-2825.html
Solidkm is offline
post #48 of 90 Old 02-01-2009, 09:30 PM Thread Starter
Solidkm
anyone have any experience/comments on these u joints? ( alloy usa) i know they arent ctms but if they are moderately better then stock 297 then i will get them
http://eastcoastgearsupply.com/i-132...t-dana-44.html
Solidkm is offline
post #49 of 90 Old 02-02-2009, 10:41 AM Thread Starter
Solidkm
anyone have any help?
Solidkm is offline
post #50 of 90 Old 02-02-2009, 01:56 PM Thread Starter
Solidkm
i guess no one likes me
Solidkm is offline
post #51 of 90 Old 02-04-2009, 06:14 PM
CaleTJ99
CaleTJ99's Avatar
bump for a friend im also interested in the waggy 44 front end for my jeep....
CaleTJ99 is offline
post #52 of 90 Old 02-04-2009, 06:46 PM Thread Starter
Solidkm
ha apparently no one cares. i will just post pictures when its done
Solidkm is offline
post #53 of 90 Old 02-08-2009, 06:00 PM Thread Starter
Solidkm
does anyone know if i went to 5 on 5.5 bolt pattern what rotors i would run in the rear for my 8.8?
Solidkm is offline
post #54 of 90 Old 02-08-2009, 06:28 PM
Greg_Volkman
most guys have just drilled their 8.8 rotors for the new pattern. I have also heard that some F-150 rotors were 5x5.5 - you can probably pull one of your 8.8 rotors and take a measuring tape and some calipers with you to the parts store to see if any of the F-150 rotors are the same.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline
post #55 of 90 Old 02-08-2009, 06:51 PM
johnjk
johnjk's Avatar
Sorry buddy!
I just redrilled my rotors.
I know Currie sells some new rotors with 5 on 5 1/2.
johnjk is offline
post #56 of 90 Old 02-08-2009, 06:56 PM
johnjk
johnjk's Avatar
got a stupid question here, but i couldnt find any real info on it. what exactly are "thick gears"? the d44 i got has 3.55 in it now. i was told if i buy thick gears it will work with that carrier? i understand they are about 30 dollars more. other then that is there any other down fall?
Got this from a quick google search:
http://classicbroncos.com/forums/showthread.php?t=84689
johnjk is offline
post #57 of 90 Old 02-08-2009, 06:58 PM
johnjk
johnjk's Avatar
is there a carrier split for the dana 44?
yes, I think it's 3.92 up - 3.73 down
johnjk is offline
post #58 of 90 Old 02-08-2009, 07:04 PM
johnjk
johnjk's Avatar
if i switch the 8.8 to 5 on 5.5 what rotor would i use?
if i take a waggy 44 and use chevy ( or is it ford) spindle to get 5 on 5.5 can i retain the hubs? and would i need a matching hub/rotor? thanks
for 5 on 5 1/2 you will need chevy small bearing spindles and Ford hub/rotors.
Did that answer your question? I'm not exactly sure what you were asking.
You could keep the 6 lug waggy and get custom 6 lug 8.8 shafts from Dutchman if you prefer.
johnjk is offline
post #59 of 90 Old 02-08-2009, 07:20 PM
Greg_Volkman
I think he already has the Superior S8.8 with c-clip elimnators
-0|||||||0-
post #60 of 90 Old 02-09-2009, 06:19 AM Thread Starter
Solidkm
wow thanks guys for the replies.
i know about thick gears now. i honestly never heard of them before last week.
i am trying to decide what lug pattern to go with. i currently am have 5/4.5 front and rear.
i am ok with running the 6 lug up front ( only thing i need are two cragars) to save money then switching at a later date. see my tires are practicalyl brand new and they are 15s so i need a 15 rim. alot that i am finding ( used/ factory rims) are bigger
my build is costing me alor more then i expected. and those spindles and hubs are expensive. there is a conversion kit on ebay ( complete) for like 350. i dont find that to be a deal... do you guys?
i picked up a waggoneer 44 for 200$ complete. with lock outs and locker. i dropped it opp at the shop to get brackets done and the guy and i were takling about castor. i told him that i needed more for my jeep and i asked him to cut off the inner C's and weld them with some angle so when i went pos. castor i didnt throw the pinion into the dirt.. well he coaxed me into going high pinion. there are alot of benifits for this i said F it. he said that it has more castor stock then the LP. and he "had them in stock" i think it will be like 350 for the housing and shortening. so that is where i stand. supposed to pick it up friday
Solidkm is offline
HP 30 or Waggy 44 goldswim5 TJ Wrangler Technical Forum 14 10-04-2009 10:17 PM
81 waggy SASKJEEPER YJ Wrangler Technical Forum 1 05-03-2008 10:35 PM
HP D44 right? 85 Waggy jeepjared84 YJ Wrangler Technical Forum 2 04-29-2007 07:03 AM
What to look for in a waggy? Dave_L YJ Wrangler Technical Forum 2 04-10-2007 11:56 AM
waggy 44, isuzu 12 bolt, waggy leaves (sua), tj flares mississippi_xj YJ Wrangler Technical Forum 6 12-08-2005 07:18 AM
