Vibration while under torque - JeepForum.com
post #1 of 12 Old 02-27-2020, 07:43 AM Thread Starter
Kc0yve
2006 Wrangler 2.4L, 114k miles
While driving, only in 2WD and 4HI, I have a bad vibration around 1800-2300 RPM. I am replacing clutch/pressure plate/associated bearings this weekend. If stationary and holding same RPM range, I am not getting the same vibration. While moving, if I push in clutch pedal, the vibration goes away. I have crawled underneath and tried moving driveshafts and everything seems fine there. It is really driving me nuts, what else should I look at?
Kc0yve is offline
post #2 of 12 Old 02-27-2020, 09:59 AM
Red Rubicon
Pull the drive shafts and check the u-joints.
Red Rubicon is offline
post #3 of 12 Old 02-27-2020, 11:46 AM
fishinjeeper
fishinjeeper's Avatar
Off and On, I have had the same issue. For me, every time it has happened, it is in relation to one of the driveshafts. There are a few parts that can go bad, u-joints, centering ball, or splines themselves. Start with removing your rear driveshaft. put it in 4WD and take it for a drive. If the vibration is gone, it will be the shaft. vise-versa for the front. It could be something in the axle like a pinion bearing, but from what I read, those make a deep growling sound in addition to vibrations.
Find God, your gonna need him.
Captain of the Little Liberator.
fishinjeeper is offline
post #4 of 12 Old 02-27-2020, 03:01 PM
ShawnAtTomWoods
ShawnAtTomWoods's Avatar
I'm willing to bet that you have a stock rear drive shaft and a couple inches of lift. Your problem sounds like a textbook example of a drive shaft shudder/vibration caused by too much angle on the stock rear drive shaft. I'm not sure if you have a Rubicon or a standard TJ. Either way, I think that a double cardan (CV) style rear drive shaft is the solution. If you have a Rubicon model, it is as simple as replacing the drive shaft and adjusting your rear control arms. If you have a non-rubicon model, you will need to do a slip yoke eliminator kit.
ShawnAtTomWoods is offline
post #5 of 12 Old 02-27-2020, 04:17 PM Thread Starter
Kc0yve
I am at stock height, no lift.
Kc0yve is offline
post #6 of 12 Old 02-27-2020, 05:12 PM
80cj
80cj's Avatar
1980 CJ5
Was the drive shaft removed or disassembled prior to the vibration? If it was removed and the yokes are not aligned properly, there will be vibration.
80cj is offline
post #7 of 12 Old 02-27-2020, 11:02 PM
ShawnAtTomWoods
I stand corrected.
post #8 of 12 Old 02-28-2020, 07:35 AM
BM3
BM3's Avatar
possible motor mount??
BM3 is offline
post #9 of 12 Old 02-28-2020, 11:19 AM
mukluk
mukluk's Avatar
I'd echo the advice to check your u-joints and add checking for a loose t-case or differential yoke.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #10 of 12 Old 02-28-2020, 01:27 PM Thread Starter
Kc0yve
Got it figured out I had a u-joint go bad and didn’t get any precursor warning’s
Kc0yve is offline
post #11 of 12 Old 02-29-2020, 04:18 AM
hdsport
Just had the same issue with my '05 TJ.
Got a new one with a grease fitting.
Be sure to orient the new u-joint so the fitting is accessible......
There is a 'backwards' install where the grease gun can't fit on the zerk.
Been there, done that.
2001 Winnebago Adv 32v MH
2008 Jeep GC , 2005 TJ
US Army Vet, 8th Army,
In God We Trust
hdsport is offline
post #12 of 12 Old 03-01-2020, 09:41 AM
Mousejockey
Vibration under load is a warning =)
Mousejockey is offline
