Vanco Kit Replacement Rotors? - JeepForum.com
post #1 of 7 Old 11-25-2015, 01:45 PM Thread Starter
0blcktj6
0blcktj6's Avatar
Hope you guys can help me out as the black magic brake website doesn't have the info and my google-fu is lacking..
I've got a 2006 TJ with the original Vanco BBK in a 15" flavor but noticed that they only have 16" rotors listed for replacement. Are they the ones I need? Anyone got any idea? Thanks
3" Currie progressives, OME Shocks, 1" BL, 1" MML, 35x12.50" KM2's, 4.88's, Detroit in rear, Vanco BBK, Currie CA's
My Build Thread:
0blcktj6 is offline
post #2 of 7 Old 11-25-2015, 03:02 PM
biffgnar
biffgnar's Avatar
Do you still have your Vanco instructions? IIRC on the first page it has a full break down of the parts and what they are if you need to replace them. The 15 and 16" kits might use the same rotor, I don't recall. I'll look around and see if I have a copy of the instructions. Blaine's probably in JV right now so it may be till the weekend that he'll be back on here to answer directly.
biffgnar is offline
post #3 of 7 Old 11-25-2015, 03:05 PM
rondak46
rondak46's Avatar
Originally Posted by 0blcktj6
Hope you guys can help me out as the black magic brake website doesn't have the info and my google-fu is lacking.. I've got a 2006 TJ with the original Vanco BBK in a 15" flavor but noticed that they only have 16" rotors listed for replacement. Are they the ones I need? Anyone got any idea? Thanks
Pretty sure you need 99 ish ford sport track rotors. The pads are the same except there are two varieties; one with an affixed clip on one pad side and one without. Just compare what you have with the explorer type and the sport track type pads and you should be able to find what you need. Hopefully mrblaine will check in and tell you for sure, but I have two kits and I think that is what you need.
rondak46 is offline
post #4 of 7 Old 11-25-2015, 03:37 PM Thread Starter
0blcktj6
0blcktj6's Avatar
Thanks fellas, yea I should have the original 46mm pads but I'm not entirely sure. I thought they were from a 98 or so explorer I just couldn't remember, it's been a long while since I've messed with them.
My Build Thread:
0blcktj6 is offline
post #5 of 7 Old 11-25-2015, 03:39 PM Thread Starter
0blcktj6
0blcktj6's Avatar
Yea I looked for the instructions but the only ones I could find were for the new generation kits. It looks like I need 15" 98 explorer rotors, probably run the centrics that are recommended with the black magic pads I just wanna make sure I'm not overlooking something.
My Build Thread:
0blcktj6 is offline
post #6 of 7 Old 11-25-2015, 05:05 PM
Jonny Jeep
Jonny Jeep's Avatar
The rotors in the kit are Centric Premium 95-01 Ford Explorer 4wd front rotors, as per the installation instructions.
Jonny Jeep is offline
post #7 of 7 Old 11-25-2015, 05:17 PM Thread Starter
0blcktj6
0blcktj6's Avatar
Love you, thanks man
My Build Thread:
0blcktj6 is offline
