Vanco big brake kit questions - JeepForum.com
 6Likes
post #1 of 28 Old 11-19-2019, 01:36 PM Thread Starter
dm56733
I wish to install a vanco big break kit on my LJ with 35 inch tires on 17 inch rims.
Mr Blaine recommended that I install the super 16 kit instead of the 17 inch kit.
Questions:
1. Do you agree that the 17 inch kit would not be the best if one does not consider price? Why? Can you have too much braking?
2. The super 16 kit includes a larger master cylinder. (The 17 doesnít) Do I need to install a larger master cylinder?
Why, If the 17 inch kit doesnít?
Thank you
dm56733 is offline
post #2 of 28 Old 11-19-2019, 02:10 PM
Red Rubicon
Blaine knows more about Jeep brakes that anyone, I would take his advice without question.
shortydog33, lindel and tworley like this.
Red Rubicon is offline
post #3 of 28 Old 11-19-2019, 03:38 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Questions:
Thank you
Blaine is the designer of that kit and the absolute guru of all things Jeep brake related. Absolutely go with his recommendations.
Jerry Bransford is online now
post #4 of 28 Old 11-19-2019, 05:32 PM
hokahay
hokahay's Avatar
Reminds me of Seinfeld.
"No soup for you!"
Joking aside, Blaine is the man, you can go to the bank with his recommendations.
hokahay is offline
post #5 of 28 Old 11-19-2019, 09:36 PM Thread Starter
dm56733
Ok, Ok, (BTW, I never doubted the guru)
Iíll order what he recommends, the super 16.
But could someone please explain why?
dm56733 is offline
post #6 of 28 Old 11-19-2019, 09:43 PM
Jerry Bransford
Administrator
I'm guessing the 17" kit may not clear all 17" wheels depending on their construction and backspacing. My dual position 15/16" Vanco combo kit barely clears my 15" Walker Evans beadlocks.
post #7 of 28 Old 11-19-2019, 10:16 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
No questions needed.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
GOT IT BACK 6/17. 03' Rubicon/Zone 4.25" combo lift with 4" lift coils up front/Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #8 of 28 Old 11-20-2019, 10:12 AM Thread Starter
dm56733
Canít we just talk about it? Knowing why things are done is part if the purpose of a forum, right? Asking why something is done or how things work is not a criticism of mr. Blaine in any way. Canít we all agree on that?
dm56733 is offline
post #9 of 28 Old 11-20-2019, 10:17 AM Thread Starter
dm56733
I donít see a dual position 15/16" Vanco combo kit? What is that? I presume that a 15 inch kit can fit on 15 and larger rims. Fair? I presume that a 16 inch kit will not fit on a 15 inch rim. Fair?
dm56733 is offline
post #10 of 28 Old 11-20-2019, 10:21 AM Thread Starter
dm56733
Btw, if I was closer to Blaineís shop I would not hesitate to bring my Jeep there and have him do the install. I would prefer that even though I believe I can do it myself, but Iím too far away to do that. His reputation is spotless.
dm56733 is offline
post #11 of 28 Old 11-20-2019, 01:48 PM
WSS
Graduate U-Tube Univ.
WSS's Avatar
A Laurel and Hardy welcome to the TJ section!!
The family TJ build:
non stock CJ's:
My CJ5 Build:
WSS is offline
post #12 of 28 Old 11-20-2019, 02:17 PM
hokahay
hokahay's Avatar
I don’t see a dual position 15/16" Vanco combo kit? What is that? I presume that a 15 inch kit can fit on 15 and larger rims. Fair? I presume that a 16 inch kit will not fit on a 15 inch rim. Fair?
I have 15" wheels and the original 44mm calipers on the modified knuckles. When I decided to replace Blaine had me upgrade to the 46mm calipers. They aren't mounted yet I want to paint them.
The brakes are cash. Even the 44mm calipers with his pads (probably without) work great. My jeep with its savvy suspension and Blaines brakes handles great. Stops like a sports car. A heavy brick shaped sports car.
TL;DR
I suggest you ask Blaine and report back.
hokahay is offline
post #13 of 28 Old 11-20-2019, 03:10 PM
Jerry Bransford
Administrator
The knuckles gave the ability to mount the calipers in the correct position for 15" or 16" wheels. I don't know that Blaine still uses knuckles like these that give the dual position option but they're what was in my early kit. The bottom of the knuckles are where the two possible 15 vs. 16" positions are for the caliper mounting bolts.
lindel likes this.
post #14 of 28 Old 11-20-2019, 03:22 PM
hokahay
hokahay's Avatar
Another question for Blaine.
At the end of the day, OP should just pony up and get the kit.
I have never seen anyone not happy with the outcome.
Only one problem with mine.
I almost got rear ended a couple times by retards following to close and on the phone.
hokahay is offline
post #15 of 28 Old 11-20-2019, 04:43 PM
lindel
lindel's Avatar
I've got the 15/16 kit. There are two over-lapped holes that will allow you to use either 15 or 16 inch rotors, depending on wheel inside diameters. Not all wheels are equal.
I actually had to change wheels because the 15" wheels that I had didn't clear the calipers, using the 15" rotor.
Lindel
1999 Flame Red Sport, with some mods...
1999 Gunmetal Sport, waiting for some mods...
lindel is offline
