Upper rear control arm bracket broken. Repairable? - JeepForum.com
post #1 of 17 Old 12-19-2011, 09:34 PM Thread Starter
Toonces
Last night I started noticing a shimmy in the rear of my 97 TJ when shifting gears. I went to run an errand this afternoon and along with the shimmy I started hearing a bump against the tub and it felt like it pulled up on the right when I shifted gears. Before I got too far I drove back home and parked the Jeep and took another vehicle. When I got back home I crawled under and found that my rear left upper control arm bracket was broken off at the axle. The other side looks normal with no cracks but as you can see from the picture. The driver's side is not so good. I've been searching on the subject of upper rear control arm breakages and nearly all the answers I found were for breakages on the body side. Is this repairable by having it welded back together or will I have to remove the whole rear end and remove the the brackets and have new ones welded on? I can see from the wear on the trackbar that it appears to have been going on for a while but must have just finally broken all the way through. Lastly, would it be safe to drive to a shop with 1 broken like this?
Toonces is offline
post #2 of 17 Old 12-19-2011, 09:41 PM
thecleaner
thecleaner's Avatar
I don't have an answer. I.just wanted to say that you folks out west with your 15 year old vehicles with virtually no rust disgust me.
You'll be amazed at how much government you'll never miss - Mitch Daniels
thecleaner is offline
post #3 of 17 Old 12-19-2011, 10:07 PM
JeepZJlover
I give that a x2 but as for help if it was my vehicle I'd tow it. But in reality if you baby it and it's only a mile or two you'll probaly make it. As for fixin it your probaly better getting a new mount put on
1993 Cherokee 4dr SE green, 4.0, Auto, HP30, 8.25, 3" lift 31" Goodyear Duratracs, Custom made front recovery bumper, Kenwood radio, 12" alpine type e subwoofer,alpine amplifier, Smittybilt xrc8 winch, tuff stuff portable winch receiver custom modified. 2002 Jeep Wrangler Sport 4.0, 5 speed, Dana 30 front, Dana 44 trac loc rear, Stock
JeepZJlover is offline
post #4 of 17 Old 12-19-2011, 10:15 PM
mcannon111
mcannon111's Avatar
you can drive it to the shop without any problems. just be light on the skinny petal.
the other upper will keep your axle from rolling, alot of people run 3 links which is essentially what you have right now haha good luck to ya man
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #5 of 17 Old 12-19-2011, 10:27 PM
LRod
LRod's Avatar
It seems to me that you do some HD wheeling, this jeep has been in a wreck, or there's something Very wrong with that type of damage! I've been looking into rear UCA rubber bushing failure on my 06 and there has been some mention of similar damage cause by polyurethane bushings? If I was you I find out what caused the damage, then do the fix.
LRod is offline
post #6 of 17 Old 12-19-2011, 10:46 PM
StvDiego
There's a couple of options: put the bracket back in position and weld it (budget fix); remove the bracket and weld in a replacement (still in budget range), upgrade to another axle like a D44 (depends on your budget..).
I have two frame mount brackets that I re-welded years ago and are stronger than before.
But, you also have to figure out why it happened to begin with. My inclination leans towards your 4" lift on stock control arms twisting the bracket. In this case it will continue to happen until you correct that with bumpstops, the correct shocks, new control arms that flex like Johnny Joints, possibly a trackbar...
Basically you need to get your lift dialed in and prevent your axle from flexing the mount (you can see how much your sway bar has moved in the mount, and remember, when off-roading your rear axle moves in an arc..). As you noted, this has been happening over time, not sure of the history of your Jeep so no way to know how long it has been happening.
In theory you could drive it a short distance, but if you're not going to do any repair yourself (welding), you will save a lot of money if you pull the axle, take it to a shop, have them weld it up and then re-install it. Potentially you could get an immediate repair for around $25 - $50
StvDiego is offline
post #7 of 17 Old 12-20-2011, 10:28 AM Thread Starter
Toonces
Thanks! I am going to take it in and get it fixed or replaced. Unfortunately, a new D44 or 8.8 isn't in my budget. Maybe the new Rancho 9000XL's that my wife got me for Christmas will help a bit along with whatever else needs to be done to get the problem resolved.
Toonces is offline
post #8 of 17 Old 12-20-2011, 11:37 AM
wushaw
Rockin jeep
wushaw's Avatar
Just weld it back together till you can do something different.
wushaw is offline
post #9 of 17 Old 12-20-2011, 12:57 PM
limeking
Don't three links have a trackbar? That looks like the driverside ca mount where the trackbar attaches. I would have it towed.
If there wasn't stuff that sucked, how would we know what was cool? Beavis and Butthead
Jeremy : )
2004 Lime Rubicon, NV3550, JKS arms, and trackbars, UCF tummy tuck, LoPro and engine skid, 3 in tera springs 33 KM2s
1994 Red Wrangler, 2.5 in lift, 31 in no names, 4.0 ax15 30/35
limeking is offline
post #10 of 17 Old 12-20-2011, 01:07 PM
mcannon111
mcannon111's Avatar
true. sorry i totally forgot that. get it towed or else your axle is going to walk around everywhere and you'll probably break more stuff
post #11 of 17 Old 12-20-2011, 02:11 PM Thread Starter
Toonces
I took it in to a place not too far from the house and got it welded. Also had my new shocks put on. The repair wasn't too bad. $50. The bushings on the old shocks were all dried out and loose. Looks like I should replace the upper control arms all the way around as the bushings on them aren't much better than the shocks were.
Toonces is offline
post #12 of 17 Old 12-20-2011, 02:19 PM
-dirt-
-dirt-'s Avatar
Do you know what caused the mount to let go?
-dirt- is offline
post #13 of 17 Old 12-20-2011, 03:30 PM Thread Starter
Toonces
Well I was told at the shop that they see this kind of break a lot on the driver side upper on both the axle and the body. Their thought pretty much echoed what stvdiego said and that the lift added stress along with the worn shock bushings that let the shocks move around that it's been tearing that bracket for a while. I didn't notice it so it's been getting progressively worse until it finally broke. They said I should replace the upper and trackbar bushings all the way around soon too. Even if I just get new factory types it will be an improvement. My lowers have already been replaced with aftermarket ones but could probably use new bushings given the state of the others. They were on it when I got it so I have no idea how old any of it is.
It seems like most places sell all urethane kits for all these bushings but I've read that I should stay away from them as they don't provide the same cushioning as rubber and provide a harsher ride. If that's so, why do all the suspension manufacturer's keep providing them? Is it more because of the application that makes them a poorer choice? Don't mean to start a religious war if this is one of those topics
Toonces is offline
post #14 of 17 Old 12-20-2011, 03:36 PM
-dirt-
-dirt-'s Avatar
Ok, just curious. Thought this might have happened during or immediately after a wheeling trip.
-dirt- is offline
post #15 of 17 Old 12-20-2011, 04:07 PM Thread Starter
Toonces
Unfortunately not. Seems like it boils down to worn suspension components. I'm sure the desert heat doesn't help that any. At least it's a great time of the year to be outside working on the Jeep
Toonces is offline
Rear upper control arm bracket - broken weld enfuego TJ Wrangler Technical Forum 11 05-06-2011 12:36 AM
Upper control arm rear bracket broken. Please help! FrontRightTIRE TJ Wrangler Technical Forum 6 08-18-2010 09:02 PM
Broken Track Bar/ Upper Control Arm Bracket dbshea TJ Wrangler Technical Forum 1 05-31-2008 04:22 PM
broken upper control arm bracket... Repaired!! losfreddy TJ Wrangler Technical Forum 3 03-08-2006 03:11 PM
broken upper control arm bracket, diagonsis bad shocks? losfreddy TJ Wrangler Technical Forum 7 03-05-2006 07:00 PM
