JeepForum.com (https://www.jeepforum.com/forum/)
-   TJ Wrangler Technical Forum (https://www.jeepforum.com/forum/f9/)
-   -   Upgrading my Rear Locker-ARB or Rubi Front Locker? (https://www.jeepforum.com/forum/f9/upgrading-my-rear-locker-arb-rubi-front-locker-563024/)
tkki1230 05-26-2008 04:19 PM
I'll be re-gearing my Rubicon to 5.13, and I was thinking of upgrading the Rear Locker at the same time. I'll be running 33's for now, and then upgrading to 35's down the road. The first option I was considering was using a Rubi Front Locker along with stock spline count alloy shafts. The second option was using an ARB with either 33 or 35 spline shafts. Another option would be to just keep the stock rear locker and upgrade to stock spline alloy shafts. The jeep is a DD, and I wheel once a month, with most of the terrain being easy to medium grade. I am more concerned with strength and durability. I use the jeep for fishing, and I often go alone, so I need the Jeep to be bulletproof.
If I go with the ARB, would it be possible to use the factory switch?
mrblaine 05-26-2008 04:42 PM
Factory front locker is a two pinion design. Arb is a 4 pinion design. Get the ARB and don't look back.
The Super 44 for what you are doing is about bulletproof.
tkki1230 05-26-2008 06:54 PM
OK- Super 44 it is.
Has anyone hooked up their ARB with the factory Rubicon switch? There were a couple of posts on another forum stating that it could be done, but the descriptions were vague. There is a Rubi that I saw where he has a separate switch for the ARB compressor and the locker itself, but when activated, the factory rear locker light in the dash flashes constantly. This must be a common thing, as I am sure that there are a lot of Rubi owners who've uupgraded to ARB's?
JeepRocks86 05-26-2008 08:40 PM
There's a guy in my club that went with 513s with his rubi.
He kept the rubi locker and it died soon after that. Then he went with an electric locker and it was built wrong. After that (third or 4th time taking the rear diff apart) he put a detroit in it.
You may be able to hook up the switch and the ARB. You would have to look at the leads for the switch itself.
Don't forget the different air compressor for the ARB.
Skeezer 05-26-2008 08:45 PM
100% Arb !
The time now is 02:59 PM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
