UCF Engine skid 2.5L install - JeepForum.com
post #1 of 8 Old 02-23-2012, 06:41 PM Thread Starter
theducksguts
theducksguts's Avatar
I recently bought the Undercover Fab aluminum engine skid and really like it. The only thing I can't figure out is how to attach it to the frame.
I thought I was missing the brackets that bolt to the engine mounts but Matt at UCF said I didn't need them.
I have been stumped trying to figure out how this goes on. I PM'd another JF member who stated they had bought the skid but they were unable to figure it out either.
Has anyone done this install for the 2.5L? I contacted UCF regarding some pictures or install instructions but have not received a return email. Otherwise I am really pleased with the product.
Check out my
theducksguts is offline
post #2 of 8 Old 02-23-2012, 09:38 PM
tjsooner
I just did the install a couple weeks ago, I thought the same thing. Matt emailed me the pictures but I already deleted them.
You have to drill a hole in each motor mount base? This part was a huge pain. Tough to get a drill in there and holes are 3/8 inch. It took me 2 hours of positioning and repositioning to finally get things lined up well. I also had to grind the edge of the skid down to be able to clear the exhaust.
Install instructions online are for the 6 cyl and all the pictures are too. I couldn't find anything online about the 4 banger. I'll snap some pictures tomorrow if you still need some help and no one else chimes in.
tjsooner is offline
post #3 of 8 Old 02-23-2012, 10:00 PM
jpfelix
there should be a hole in the driver's side mount already, but there is not one in the passenger side mount. i had enough room to get a drill inbetween the frame and inner fender.
let me see if i can find some pictures.
jpfelix is offline
post #4 of 8 Old 02-23-2012, 10:08 PM
jpfelix
driver's side mount with hole:
jpfelix is offline
post #5 of 8 Old 02-23-2012, 11:42 PM
undercoverfab
Vendor
undercoverfab's Avatar
I just emailed you over a couple pics. I will try to post them here in the morning.
Thanks,
Matt Walton
(334) 446-3821
Use the coupon code "jeepforum.com" to save 10% today!
Check us out on
undercoverfab is offline
post #6 of 8 Old 02-23-2012, 11:52 PM Thread Starter
theducksguts
Thanks again. I got the photos from the email.
Looks like the install is going to be pretty straight forward. I was looking at other TJ's with the 4.0 and didn't realize that the frame stantions for the motor mounts were that much different in comparison to the 2.5L. Go figure.
Check out my
post #7 of 8 Old 02-23-2012, 11:55 PM Thread Starter
theducksguts
My fenders have been off recently so there is only a few bolts holding them on right now, that should help a ton.
I'm excited to go over to the shop and start the project.
Check out my
post #8 of 8 Old 03-06-2012, 10:43 PM
r_unda
r_unda's Avatar
After having the skid plate in my garage for a little less than a year I finally installed it tonight. I went a different route since I didnít want to drill near the engine mount due to lack of space. I ordered the mount brackets in the photo below from another well known engine skid plate vendor. I modified one of it at work in order to bolt it on the passenger side (vendor only sells driver side bracket).
After bolting everything all I did was to drill into the UCF tummy tuck to bolt the engine skid plate. I am happy with the results.
My Jeep isn't getting older, it's getting newer part by part
2011 WK2 HEMI 4x4 Overland
2007 WK CRD 4x4 Limited GDE Tuned
1998 TJ SE
1973 CJ5 - YJ OME 2.5" lift, 33" tires
1951 Willys truck
r_unda is offline
UFC engine skid install help please... kllrbee TJ Wrangler Technical Forum 20 11-07-2010 08:09 PM
UCF Engine skid install ? Weeeee TJ Wrangler Technical Forum 2 07-18-2010 12:07 PM
Install issue with Skid Row engine skid gaTJgal TJ Wrangler Technical Forum 35 10-25-2009 05:50 PM
Engine Skid Install Trombino TJ Wrangler Technical Forum 4 07-23-2006 05:57 PM
