Two Pilot bearings? - JeepForum.com
 3Likes
  • 1 Post By TheBoogieman
  • 1 Post By Occulus
  • 1 Post By WallyDog1
post #1 of 8 Old 06-20-2021, 07:44 PM Thread Starter
Occulus
Two Pilot bearings?
So I'm changing the clutch, flywheel, etc etc on my 2004 TJ with a 5-speed. The Luk clutch kit came with a new pilot bearing so I figured I would change that too except there was two I pulled out. At least I think it's two pilot bearings. Is this right? There is suppose to be two or did I screw up and pull something out that I shouldn't have? First time doing it.
Occulus is offline
post #2 of 8 Old 06-20-2021, 09:39 PM
ravenworks
ravenworks's Avatar
Should only be one and the proper length
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #3 of 8 Old 06-20-2021, 10:15 PM Thread Starter
Occulus
Thanks! That's what I was thinking since all the videos show only one. I assume the former owner hammered two in but why?
Occulus is offline
post #4 of 8 Old 06-21-2021, 06:09 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
The pilot bearing wasn't able to do it's job and needed a co-pilot.
222Doc likes this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
2003' Rubicon/Zone 4.25" combo lift with Rancho RS5000X shocks/ Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #5 of 8 Old 06-21-2021, 06:31 AM Thread Starter
Occulus
hahahahahahaha, a co-pilot bearing
TheBoogieman likes this.
Occulus is offline
post #6 of 8 Old 06-21-2021, 04:32 PM
WallyDog1
WallyDog1's Avatar
WallyDog1
They probably couldn't figure out how to get the old one out so they just pounded the new one in. The crank needless to say is deep enough to accept two. The trans main shaft was using only the one bearing closest to the end.
Jerry Bransford likes this.
From the Smoky Mountains of Western North Carolina
WallyDog1 is offline
post #7 of 8 Old 06-22-2021, 09:42 AM
53flattie
53flattie's Avatar
1936 CJ2A
A word of caution (from personal experience) - on my 2004 Rubicon, the pilot bearing is NOT supposed to look like this. If it did, it’s possible that someone added the second pilot bearing to make up the difference in depth.
It SHOULD look like this:
That little “oversight” cost me a second removal and reinstall of the transmission…
Sent from my iPhone using Tapatalk
53flattie is offline
post #8 of 8 Old 06-22-2021, 09:56 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That was my bet, it takes a bit of proper technique to get the old bearing out. I used a blind bearing puller but others pack the area with grease and use a dowel or similar tool to push it out hydraulically.
Jerry Bransford is offline
