Tummy tuck question - Page 2 - JeepForum.com
post #16 of 38 Old 04-05-2013, 09:35 AM Thread Starter
Ljcrawler05
Originally Posted by Jrob05 View Post
You will probably need an angled rear track bar bracket when you do the TT. I did. You rotate the rear pinion a lot when you go to a DC shaft.
any suggestions on the bracket? I want to go currie or metalcloak with the track bars, but it'll be a while so the bracket is all I really need
Ljcrawler05 is offline
post #17 of 38 Old 04-05-2013, 11:43 AM
Jrob05
Jrob05's Avatar
I personally got the savvy/currie bar with dual JJs, with HD bracket. I'd post up a link but I don't see the particular one I have on the site. May have to give Gerald a call.
Jrob05 is offline
post #18 of 38 Old 04-05-2013, 11:49 AM
toberste
I run the Currie track bars front and rear that I got from savvy. Got the rear with the bracket and I am only on 3" of lift. I don't see how I could have rotated the axle as much as you need to with the under armor without the bracket. I may be wrong but somethins tellin me in the back of my head that you cant run the stock track bar with the bracket unless there is some sort of spacer but dont hold me to that. Call Gerald at Savvy he'll get you set up good. Also the underarmor comes with the exhaust hanger, it is adjustable so you can get it lined up good.
toberste is offline
post #19 of 38 Old 04-05-2013, 11:55 AM
biffgnar
biffgnar's Avatar
A stock rear TB will work with some angled brackets (e.g. RE), but the Currie bracket is wider to fit the JJ so will not.
biffgnar is offline
post #20 of 38 Old 04-05-2013, 12:01 PM
homebrwd
I just ordered a JKS bracket for my tummy tuck on my TJ. The trackbar from metalcloak already has the angle in it to account for the pinion angle change if you are looking to go that way. Otherwise the JKS bracket should work.
homebrwd is offline
post #21 of 38 Old 04-05-2013, 12:09 PM
toberste
Thank you for confirming that. I knew I wasn't crazy !
toberste is offline
post #22 of 38 Old 04-05-2013, 12:13 PM
rikkards
rikkards's Avatar
If you get the angled bracket and adjustable rear trackbar, make sure before putting them on that the trackbar fits in the bracket. I got the Currie ones and had a bear of a time getting the trackbar to fit. It seems like the bracket was about 1/16" smaller than the JJ. With a bit of persuasion, some swearing and brute force I was able to get it in.
Machete don't tweet
- Machete
rikkards is offline
post #23 of 38 Old 04-06-2013, 02:38 PM
IEcrawlerTJ01
IEcrawlerTJ01's Avatar
Whenever thy happens whether it be track bar mount or lca mount or whatever. I just grab a decent sized crescent wrench and bend each tab a lil bit. Once you slid in and bolt down. It closes right back up
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #24 of 38 Old 04-06-2013, 03:00 PM
rikkards
rikkards's Avatar
Easier said than done when it is 1/4" thick But yeah more or less that was what I did
Machete don't tweet
- Machete
rikkards is offline
post #25 of 38 Old 04-07-2013, 03:45 PM
Sahara707
Sahara707's Avatar
309.00 less ROKMEN10 discount code, that's about 278.00. No affiliation with Rokmen, I just bought one for my 2000 TJ.
Sahara707 is offline
post #26 of 38 Old 04-07-2013, 08:10 PM
rikkards
rikkards's Avatar
It's a nice skid but doesn't look like you gain any clearance over the stock. I gained about 3 inches when I put on my UHC skid over stock. Course everything is nicely cramped in there now even with a BL.
Machete don't tweet
- Machete
rikkards is offline
post #27 of 38 Old 04-08-2013, 07:40 AM
UnlimitedMatt
Rokmen gains about 2.25 over the stock pan.
2005 Unlimited Rubicon, Sahara Edition #556, Colorado Jeep Club Member #556
Rusty, if you are reading this, I am still waiting for my $249 refund from 06/2010. Pm me for my address to send the check. Thanks!
UnlimitedMatt is offline
post #28 of 38 Old 04-08-2013, 08:04 AM Thread Starter
Ljcrawler05
How do they address the exhaust clearance
post #29 of 38 Old 04-08-2013, 08:27 AM
UnlimitedMatt
Before I installed my Rokmen pan, I installed a 1/2 inch bl, mml and the Novak transfer case cable to avoid possible issues.
When I initially installed my belly pan, I didn't modify my exhaust as they say not everyone needs to. Needless to say, I needed to.
I called Rokmen (they were super friendly) and they suggested to cut 5/8 of an inch off of the hanger.
I did this and it is now perfect.
post #30 of 38 Old 04-08-2013, 08:31 AM Thread Starter
Ljcrawler05
Alright, but I've got a 1.25" body lift and novak sitting at the house waiting to be installed so I would probably be good on that but I guess I'll just have to put the skid on and see where I'm at is the basic answer. I'd really prefer to not have to mess with it, but will do if necessary
savvy offroad
