tub lining? - JeepForum.com
post #1 of 11 Old 05-02-2009, 10:16 PM Thread Starter
max9991
tub lining?
looking to line my tub but dont have near the $500 for someone else to do it
has any one used the duplicolor bed liner??
if so how is it
and ive heard good things on herculiner too?
max9991 is offline
post #2 of 11 Old 05-02-2009, 10:21 PM
Alexia
Alexia's Avatar
If you are looking to do it yourself, U-POL Raptor is a very good choice. It requires to be sprayed on though so you would need a good air compressor.
http://www.tptools.com/p/2600,233_U-...Liner-Kit.html
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Alexia is offline
post #3 of 11 Old 05-02-2009, 10:27 PM Thread Starter
max9991
yeah i heard that was pretty good too
and my friend has a decent air compressor
max9991 is offline
post #4 of 11 Old 05-02-2009, 10:30 PM
USAFRecon
USAFRecon's Avatar
I herc'd the inside of my tub. Cost $55 for the kit at wally world, rolled it on myself and has stood up to all kinds of abuse of the year its been on. Highly recommend that.
USAFRecon is offline
post #5 of 11 Old 05-02-2009, 10:45 PM
Greenturd
Guest
x2 on herc, I did it too, but used the plastiloke stuff from wally world; still really good.
the best thing to do is take your time in the prep, there is plenty of write ups were just search
Greenturd is offline
post #6 of 11 Old 05-02-2009, 10:51 PM
eagleman06
eagleman06's Avatar
i just did the duplicolor bed liner in mine last weekend. So far i like the way it turned out but i am not finished yet. All i have done is the rear and tail gate. It isnt as thick as i was thinking it would be but i may end up putting a few more coats of it on. Prep is definetly the key if you want this stuff to stick properly.
eagleman06 is offline
post #7 of 11 Old 05-02-2009, 10:58 PM
FrenchToastKing
FrenchToastKing's Avatar
im in there with the herculiner. make sure you take your time in doing prep, because i have seen the stuff flake off due to a quick and sloppy prep job on another rig.
FrenchToastKing is offline
post #8 of 11 Old 05-02-2009, 11:00 PM
Muratus
Muratus's Avatar
How hard does the Herc get? Like is it abrasive?
I've used the Duplicolor before, and it had a bit of a rubbery feeling to it, if memory serves.
I have 2 young kids that love to crawl around in the back of my Jeep, so I've been leaning toward the Duplicolor. I was just wondering how the Herc would be on them.
Muratus is offline
post #9 of 11 Old 05-02-2009, 11:14 PM
becker21603
becker21603's Avatar
i did herculiner, it has been on for 2+years now and it has held up good. it is very abrasive though, so if you are worried about that for your kids i'd just find a place likes sams or costco that does line-x.
5.5" RE LA, 35x12.50 MT MTZ, Eagle Alloy rims, Hella Lights, RE adjustable track bars, Rhino lined, SYE kit custom driveshaft, Warn front and rear bumpers w/ tire carrier, Warn tabor 9k winch, ARB rock sliders, Tru-trac, 4.11's, ARB Snorkel.
becker21603 is offline
post #10 of 11 Old 05-02-2009, 11:38 PM
jmalys
any squids???
Any squids or costies out there???
It would probably be crappy but some lying down some non skid like on a cutter would be pretty abrasive!!! I would imagine it would be pretty durable too, it last pretty well on coast guard cutters. I am not sure exactly what it is though, have to find a boatswain for that info. Although it would be rough on bare feet that is for sure.
jmalys is offline
post #11 of 11 Old 05-02-2009, 11:46 PM
TJ Clay
I did the duplicolor about 6 weeks ago and it came out great. Its not nearly as rough as herculiner but also not as thick. It comes out great sprayed and you can vary the texture by the air pressure and distance. Also it comes in spray cans so touch up is simple.
99 TJ 4.0 auto, pe8000, 3" full traction, 33s, bestop tire carrier
TJ Clay is offline
Tub Lining Crowboy300 TJ Wrangler Technical Forum 7 04-04-2006 07:06 PM
Lining the tub mookarma TJ Wrangler Technical Forum 14 12-22-2005 04:58 PM
lining the tub??????? sasquatch3805 YJ Wrangler Technical Forum 10 07-10-2005 07:15 PM
Bed lining my Yj?!? Jeepn22YJ YJ Wrangler Technical Forum 5 01-29-2004 04:13 PM
lining the tub jeepthing2000 TJ Wrangler Technical Forum 7 08-21-2003 01:13 AM
