Trimming a 231 tcase - JeepForum.com
post #1 of 30 Old 04-28-2016, 03:50 PM Thread Starter
tworley
tworley's Avatar
Working on installing my savvy skid plate and am having issues with the cross member. I need to take a dremmel to it so it fits over the poppet bore (where my pointer finger is at), but a chunk of metal from the tcase is right in the way of my mounting location for the transmission mount (where my middle finger is at), can I take an angle grinder to that and trim that piece down a bit? Curious if there is anything under (or inside it) that would cause any issue...
Colorado Member 307
tworley is offline
post #2 of 30 Old 04-28-2016, 04:19 PM
BYuen
BYuen's Avatar
I had to take an angle grinder to the crossmember in that same spot. Also needed to shift the transfer case over to the driver's side with a ratchet strap.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #3 of 30 Old 04-28-2016, 11:03 PM
Hosejockey61
Bump for the OP.
Any insight or opinion on grinding the t-case nub?
Hosejockey61 is offline
post #4 of 30 Old 04-29-2016, 04:45 AM
BYuen
BYuen's Avatar
Originally Posted by Hosejockey61
Bump for the OP. Any insight or opinion on grinding the t-case nub?
I would grind the crossmember before grinding the tcase. Looks like his drivetrain also needs to shift over to the driver's side some more too which will yield more clearance for the nub go fit in the crossmember cutout.
2001 White TJ Sport
BYuen is offline
post #5 of 30 Old 04-29-2016, 05:38 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
That nub that sticks down doesn't do anything of value and removing it won't hurt the case. Grinding the cross member takes away some strength.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #6 of 30 Old 04-29-2016, 08:43 AM Thread Starter
tworley
tworley's Avatar
Thanks, fellas.
Off with the nub!
Colorado Member 307
tworley is offline
post #7 of 30 Old 04-29-2016, 08:47 AM
NotURMailman
NotURMailman's Avatar
Originally Posted by tworley View Post
Thanks, fellas.
Off with the nub!
I just had an Alice In Wonderland flash back
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #8 of 30 Old 04-29-2016, 08:53 AM Thread Starter
tworley
tworley's Avatar
That was the reference I was going for
Colorado Member 307
tworley is offline
post #9 of 30 Old 05-02-2016, 02:57 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
What does the instructions or someone from savvy say?
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #10 of 30 Old 05-02-2016, 03:25 PM
freeskier93
Someone from Savvy already answered.
freeskier93 is offline
post #11 of 30 Old 05-02-2016, 05:08 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
That guy doesnt work for savvy and has repeatedly said that.
16 Taco
dayriesw is offline
post #12 of 30 Old 05-02-2016, 06:00 PM
JEK3
JEK3's Avatar
But he does provide them a lot of technical support and assistance.
JEK3 is offline
post #13 of 30 Old 05-02-2016, 06:10 PM
jjvw
jjvw's Avatar
2003 Rubicon
jjvw is offline
post #14 of 30 Old 05-02-2016, 07:03 PM
rikkards
rikkards's Avatar
Well he doesnt, and multiple times he has said he doesnt state what Gerald wants to do with the company. Granted, Gerald would probably defer in this case to what Blaine said.
Machete don't tweet
- Machete
rikkards is offline
post #15 of 30 Old 05-02-2016, 07:38 PM
freeskier93
So what? Either way he's designed most of their products, what better word do you want?
