Tried the YJ brake line mod... they dont fit - JeepForum.com
 3Likes
  • 2 Post By toximus
  • 1 Post By tworley
post #1 of 15 Old 01-08-2019, 04:01 PM Thread Starter
173djeep
So I bought some YJ brake lines from autozone to replace my front brake lines after reading that this is a common mod to get some extended brake lines for cheap. When I went to mount them to the caliper they do not fit. It looks like I could grind down the flat surface on the line that mates up to the flat surface on the caliper but being that these are brake lines I didnt want to do anything that could cause the brakes to fail. Has anyone run into this? The part numbers are 70293 and 78121.
173djeep is offline
post #2 of 15 Old 01-08-2019, 04:15 PM
biffgnar
biffgnar's Avatar
If you are talking about grinding off a little of the circle that the banjo bolt goes through grind away. If you look at the Vanco Big Brake kit install instructions on blackmagicbrakes.com you will see it described as a step there.
biffgnar is offline
post #3 of 15 Old 01-08-2019, 04:30 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Grinding is sometimes needed, I had to grind mine too. Here are my before & after photos.
Jerry Bransford is offline
post #4 of 15 Old 01-08-2019, 05:14 PM Thread Starter
173djeep
Grind away I will. Thanks for the help guys
173djeep is offline
post #5 of 15 Old 01-08-2019, 08:04 PM
toximus
Cover the hole while grinding. You don't want any bits mixing with the fluid!
rikkards and 173djeep like this.
Building the right way for 37s.
toximus is online now
post #6 of 15 Old 01-08-2019, 08:37 PM
MrAndersonJeep
I have a 97 TJ and did the mod and didn't have to grind. I haven't double checked the part numbers but I don't see an issue with grinding that little area. The first time out with them I did bend the metal tube section of the line though. I have since been to Moab and it hasn't done it again so I'm guessing it was a fluke. Seems like a legit swap!
97 TJ 4.0
85 CJ 4.0 Swap
MrAndersonJeep is offline
post #7 of 15 Old 01-08-2019, 10:31 PM
jjvw
jjvw's Avatar
My YJ brake lines also fit. The only change I made was to use thicker copper washers.
Raybestos BH38862
Raybestos BH38861
2003 Rubicon
2003 Rubicon
jjvw is offline
post #8 of 15 Old 01-08-2019, 10:54 PM Thread Starter
173djeep
Maybe it has something to do with these being autozone brand, I never really use their parts but the store down the street had them in stock so i gave them a shot.
173djeep is offline
post #9 of 15 Old 01-09-2019, 05:02 AM
JEK3
JEK3's Avatar
I tried to do this mod, but the YJ brake lines I got were the same length as the lines that came on my LJ.
JEK3 is offline
post #10 of 15 Old 01-09-2019, 09:11 AM
tworley
tworley's Avatar
Raybestos BH38862
Raybestos BH38861
2003 Rubicon
Same ones I am using, IIRC the sides are even flat to fit.
jjvw likes this.
Colorado Member 307
tworley is offline
post #11 of 15 Old 01-09-2019, 09:38 AM
dbbd1
dbbd1's Avatar
Did you go with these due to a high lift or just because?
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #12 of 15 Old 01-09-2019, 09:54 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
It's needed with a 4" lift and disconnecting the sway bar.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
GOT IT BACK 6/17. 03' Rubicon/Zone 4.25" combo lift with 4" lift coils up front/Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #13 of 15 Old 01-09-2019, 12:42 PM
jjvw
jjvw's Avatar
I added longer brake lines when I noticed that a 22.5" long shock was getting close to pulling the stock hoses tight at full extension. This was going on at about 2" of spring lift.
Hang the axle from the shocks and turn the steering back and forth to see what is really happening.
2003 Rubicon
2003 Rubicon
jjvw is offline
post #14 of 15 Old 01-09-2019, 01:01 PM
dbbd1
dbbd1's Avatar
Thanks to both of you.
-John Wayne
dbbd1 is offline
post #15 of 15 Old 01-09-2019, 01:25 PM Thread Starter
173djeep
So the passenger side fit fine without any grinding necessary. I compared the driver and passenger side lines and noticed that the driver side was a little larger than the passenger side, so just a defect in the product I guess. A little grinding and it fit just fine.
173djeep is offline
