Transfer Case Draining - JeepForum.com
 1Likes
  • 1 Post By Mattific
post #1 of 8 Old 08-17-2021, 12:39 PM Thread Starter
BlueFl.Wrangler
Supporting Member
BlueFl.Wrangler's Avatar
What do you folks do as far as being able to collect the draining fluid out of the transfer case? Do you fellas drop the skid plate? That seems like a ton of work-- or do you just let it drain onto it and sop it all up?
Thanks
Diplomacy is the art of telling people to go to hell in such a way that they ask for directions
Winston Churchill
BlueFl.Wrangler is offline
post #2 of 8 Old 08-17-2021, 01:54 PM
Mattific
Mattific's Avatar
The skid plate has a convenient indent and hole right below the drain plug so I just let it drain out of there and wipe it clean after
BlueFl.Wrangler likes this.
Mattific is offline
post #3 of 8 Old 08-17-2021, 06:08 PM
rcroane
Cut a plastic bottle to channel the fluid into a drain pan.
rcroane is offline
post #4 of 8 Old 08-18-2021, 10:00 AM
YJ94SBC
YJ94SBC's Avatar
This may not work for your application, since I have a YJ with a D300 TC.
I use a disposable aluminum cooking tray, I’m able to bend it enough to catch the gear oil and then I transfer it into an oil pan. I hate the smell of gear oil, and letting it drip on your skip plate and wiping it up, had my garage smelling horribly for days.
YJ94SBC is offline
post #5 of 8 Old 08-18-2021, 11:09 AM
Jeepsr4me
let it drain.. The little that gets in teh skid plate is not a huge worry..
I use to just jack the front up a little higher and this way it directs the oil out and over that lip. Or a simple piece of cardboard to make a ramp out...
Jeepsr4me is offline
post #6 of 8 Old 08-19-2021, 10:12 AM Thread Starter
BlueFl.Wrangler
Supporting Member
Thanks fellas
Winston Churchill
post #7 of 8 Old 08-19-2021, 03:02 PM
Temujin
Junior Member
Temujin's Avatar
You could also go in threw the fill hole with a 10 dollar advance auto pump and pump out as much as you can then open the drain plug if there is no hole in the skip plate for the oil to drain. Then put rags on the skid plate before you open the drain plug. saves time with cleaning up after a real mess if there is no drain hole in the skidplate.
1995 zj 4.0 242 6l 42re trans 242 transfer case 27 spline dana 30 front 35 rear
Temujin is offline
post #8 of 8 Old 08-19-2021, 06:05 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
HD aluminum foil can be easily formed into a combination catch basin/funnel that will drain its ATF into a bottle.
Jerry Bransford is offline
