Track bar brackets - JeepForum.com
post #1 of 10 Old 08-29-2016, 08:25 PM Thread Starter
drewtj05
Track bar brackets
I've been looking at some ways to increase the strength of the axle brackets on both the front and the rear. I wanted to know if anyone has any experience with these and to see if they are a viable option purely to add rigidity over the stock thin metal. And just to be clear ahead of time this is the only Rustys product I have ever considered thinking that it would be pretty hard to mess this up as far as design. Using it with a MC trackbar front and stock rear.
Currie Rear Trackbar Brace
https://www.northridge4x4.com/fits/2...-bracket-brace
RE Front Trackbar Bracket
http://www.rubiconexpress.com/Suspen...pn=R%2fERE9989
Rusty Front Trackbar Bracket
http://www.rustysoffroad.com/rustys-...-tj-xj-zj.html
05 Wrangler AEV/METALCLOAK/OME
12 GC Limited
For Sale
KC Light brackets
drewtj05 is offline
post #2 of 10 Old 08-30-2016, 09:50 AM
LJ Dave
If you are looking for a bolt-on solution for the rear, I recommend the Tri-County Gear rear track bar brace. I've been running it for 11 years on my 05 LJR. A couple of years ago I was towing a 4 runner a few miles with a strap. We were going down a two lane highway and I made a left turn, but the driver behind me hit the brakes. When the strap pulled snug, it jerked the back of my rig sideways a few feet and snapped the aftermarket (RE) rear track bar extension bracket into two pieces. The brace did it's job and completely protected the factory bracket. I was really glad I had it. It works and is a piece of cake to install.
http://www.tricountygear.com/product...rack-bar-brace
2005 Rubicon LJ 4.5 inches of lift, 35's
LJ Dave is offline
post #3 of 10 Old 08-30-2016, 10:01 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X2 on the Tri-County Gear track bar brace recommendation, I have had one on both of my TJs.
You can see it below, it's blue and connects the bracket to the pumpkin.
Jerry Bransford is offline
post #4 of 10 Old 08-30-2016, 02:40 PM
Du510
Du510's Avatar
This Tri-County Gear brace, what axles does it line up to?
'97 TJ
Du510 is offline
post #5 of 10 Old 08-30-2016, 02:53 PM
Jerry Bransford
Administrator
You're gonna have to call them, I dunno what other axles they have braces for beside the Dana 44 mine is installed on.
http://www.tricountygear.com/product...ox-description
post #6 of 10 Old 08-30-2016, 03:03 PM
Du510
Du510's Avatar
Just emailed them - Ill post up here when I hear.
'97 TJ
Du510 is offline
post #7 of 10 Old 08-30-2016, 03:13 PM
Jerry Bransford
Administrator
Just call them, you'll get an immediate answer.
post #8 of 10 Old 08-30-2016, 03:18 PM
biffgnar
biffgnar's Avatar
In 2016 . . . use the telephone . . . what a crazy concept. Jerry, you're living in the past.
biffgnar is offline
post #9 of 10 Old 08-30-2016, 03:23 PM
Du510
Du510's Avatar
Not sure my phone has the "call" option!
'97 TJ
Du510 is offline
post #10 of 10 Old 08-30-2016, 08:28 PM Thread Starter
drewtj05
If this does in fact bolt up to a D35 it sounds like a great option. Does anyone know if it works with aftermarket diff covers?
As far as the front does anyone have any recommendations?
12 GC Limited
For Sale
KC Light brackets
drewtj05 is offline
