total newb - wheel lug ripped bolt out of axel...what to do? - JeepForum.com
post #1 of 4 Old 06-25-2008, 04:33 PM Thread Starter
bortz1892
so the bolt ripped the stud out of the wheel, so theres only 4 left. i just came from driving a volkswagen for 7 years....how do i fix this problem, do i need to get a whole new axel?
bortz1892 is offline
post #2 of 4 Old 06-25-2008, 04:42 PM
Brown Dog
Vendor
Brown Dog's Avatar
No, just get a new stud at an auto parts store. It goes in from the back. Generally a pretty easy fix.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #3 of 4 Old 06-25-2008, 06:22 PM
CrawlinLJ
when the stud pulled out through the wheel I am assuming that is sheared off. If this is the case then what brown dog said is correct. You might have to knock out the old piece of the stud remaining and then feed the new one in from the rear. If there is no room, you might have to pull the axle to get it in. The back of the stud is splined a little bit bigger than the hole . use a couple of nuts as spacers to pull the nut into the hole if you can. If the hole was damaged and is now larger than the spline and the lug fits loose you can feed it through the hole in the axle flange and weld in on the back side so it wont turn. . All in all an easy fix.
2006 Rubicon LJ, 4.0 liter, 4 speed automatic, 5.5" Rubicon Express, 37" x 12.5" Krawlers on Champion Beadlocks, Dynatrac Pro-Rock 60 axles/5.13 ratio w/ high steering kit, Dyna-Loc front hubs, J.E. Reel 1350 cv drivelines, Atlas 4 speed/5.38:1, Walker Evans Shocks, PSC Hydraulic Assist steering, Nth Degree Oil Pan and Transmission Skid, Premier Power Welder, Kilby On Board Air, Warn 9500si, Dual Optimas, Hansen Front Bumber, All J Products Rear Bumper & Boulder Bars, PIAA Driving Lights, Rock Lights, Ham Radio, CB, Garmin 76cs GPS,Wet-Okeole seat covers
CrawlinLJ is offline
post #4 of 4 Old 06-26-2008, 02:43 PM Thread Starter
bortz1892
awesome, thanks alot guys. sounds easy enough.
Clicking/clunking noise possibly front axel in 4 wheel drive threefore YJ Wrangler Technical Forum 3 12-21-2009 03:59 PM
Newb qustion about arrow light in front of steering wheel j_nition YJ Wrangler Technical Forum 15 10-21-2006 08:04 PM
Replacing The U Joint Between The Front Wheel And Axel brrempel TJ Wrangler Technical Forum 7 09-27-2005 02:07 PM
Axel Ratio vs Wheel Size Question Niles TJ Wrangler Technical Forum 34 11-16-2004 10:34 PM
dumb wheel question from a newb. Evilgrin YJ Wrangler Technical Forum 5 10-10-2003 11:35 PM
