Torque limiting sleeves - JeepForum.com
post #1 of 14 Old 11-15-2019, 11:19 PM Thread Starter
max.
I'm stuck in my engine rebuilding process because the PO threw out the torque limiting sleeves (metal). I got the new rubber pieces with my kit. Anyone got any for sale or worst case scenario could I install the valve cover with just regular washers + the new rubber pieces? Been stumped for a few days now 😞 can't believe they disconnected the part. I'd rather kick rocks right now.
max. is offline
post #2 of 14 Old 11-15-2019, 11:47 PM Thread Starter
max.
Or could I try using this? https://shop.advanceautoparts.com/p/...0aAu7aEALw_wcB
It has the built in metal things?
max. is offline
post #3 of 14 Old 11-16-2019, 08:35 AM
Jeepsr4me
yeah a new fel pro gasket has them.. and its one of the best gaskets for our 4.0 engines..
Jeepsr4me is offline
post #4 of 14 Old 11-16-2019, 10:11 AM Thread Starter
max.
I need the metal sleeves, the one I got with my rebuild kit only comes with the rubber part not the metal that I'm looking for. 🙂
max. is offline
post #5 of 14 Old 11-16-2019, 01:50 PM
Jeepsr4me
then you did not get a felpro..)&)(&()().. Those sleeves were used by the oem and are not needed with the new gasket.
see them in the pic?
post #6 of 14 Old 11-16-2019, 02:54 PM
hokahay
hokahay's Avatar
My experience is yes you do need the sleeves. No they are not supplied by the FelPro.
I enjoyed the same issue. A mechanic tossed them. Oil leaks til the cows came home. Torque and retighten to the cows come home. No Joy.
A smarter mechanic figured out they were missing. Harder than hen's teeth to come by. I scored and found a guy specializing in TJs. He actually hand delivered a set to my mechanic within 30 minutes.
They are long discontinued by MOPAR.
The felpro only comes with grommets. You need those as well.
So while I can't solve your immediate problem offhand, I do know of what you speak lol.
You need them.
hokahay is offline
post #7 of 14 Old 11-16-2019, 03:04 PM
hokahay
hokahay's Avatar
Here is the part number from the Service manual. Item 16.
hokahay is offline
post #8 of 14 Old 11-16-2019, 03:10 PM Thread Starter
max.
Yeah I see them. Do you have a link to the product? It says it's not compatible with my Jeep. Or is the website just wrong and it'll work fine?
max. is offline
post #9 of 14 Old 11-16-2019, 03:14 PM Thread Starter
max.
Thank you but the part had been discontinued for years now and not a single dealer in the country has any left 🙂 lol
Edit: realized you posted twice and know that the part is discontinued. My apologies but yuppers that's the part.
max. is offline
post #10 of 14 Old 11-16-2019, 04:51 PM
Jeepsr4me
I have a old valve cover laying on my work bench with the sleeve still in it..
I have only pulled a few 100 4.0s and replaced about 1/2 of the valve covers with that felpro with no leaks.
so not really seeing them needed..
post #11 of 14 Old 11-16-2019, 05:02 PM Thread Starter
max.
Only a few? Lmao. Do you have the part # or anything for that felpro gasket? 🙂
max. is offline
post #12 of 14 Old 11-17-2019, 03:01 AM
2jhanna
How about making some from steel tubing, like brake line, fuel line, copper tubing, etc.
Get the correct diameter and cut to length.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #13 of 14 Old 11-18-2019, 05:30 PM Thread Starter
max.
Ended up getting 40ish of them for free from a pick n pull 🙂 crisis solved
max. is offline
post #14 of 14 Old 11-19-2019, 05:40 PM
hokahay
hokahay's Avatar
Kewl beans, dude.
Glad to hear it!
hokahay is offline
