TJ Stalling problem!!! HELP - JeepForum.com
post #1 of 5 Old 05-07-2014, 08:53 PM Thread Starter
Riley
Battery died last night because I accidentally turned on and left my interior lights on... All day today my car has been stalling when it comes to a stop, will idle at about 1-200 rpms, shakes like if I dropped the clutch to fast, it is a standard, and then it'll turn off, have no idea why.... Anyone have the same problem? Also, not sure if this is posted in the right thread, sorry if it's not!
Riley is offline
post #2 of 5 Old 05-07-2014, 09:18 PM
white305
you may want to try charging the battery up and make sure your alternator is charging properly. once you have done that and still have issues, you will have to dig a little deeper. not sure if this helps, but I would start there.
white305 is offline
post #3 of 5 Old 05-08-2014, 05:59 AM
bigred33
Battery, alternator, crank sensor, ignition coil would be things to check. If you know you killed the battery I would start there.
bigred33 is offline
post #4 of 5 Old 05-08-2014, 07:13 AM
MAMMOTH
Wooly Member
MAMMOTH's Avatar
Put a battery charger on the battery. TJ's need good voltage or they tend to do this.
2004 TJ Rubicon - 3" lift, 1" BL, Brown Dog MML with Super brackets, 33's, Warn Winch, VanCo BBK - (Thanks MisfitSeven), IronRock tierod, Ten Factory shafts.
Future upgrades - Too many to list
1999 XJ - DD with 228k
2007 JK Unlimited - The wife's ride.
MAMMOTH is offline
post #5 of 5 Old 05-08-2014, 07:15 AM
agn015
Check the battery and replace it.
I had the same issue after I left my lights on and killed the battery. I jump started it but it would barely run after I jumped it. I had to rev the engine constantly to keep it from dying. After about 15 minutes of driving/not letting the revs drop, it would finally idle and take the charge from the alternator. I replaced the battery and never had a problem since.
agn015 is offline
battery , engine , fuel , gas , stalling
