TJ Shopping How to Tell - JeepForum.com
 6Likes
post #1 of 17 Old 01-06-2019, 05:14 PM Thread Starter
ChrisWar1
Shopping for a TJ. Prefer 2002-2006. Rubicons are a lot more $. How can I tell a real Rubicon? Is there a code on the VIN tag, something to tell for sure?
BTW looking for a jeep to trail ride locally.
Also are the manual trans more reliable for these years?
Thanks,
Chris
ChrisWar1 is offline
post #2 of 17 Old 01-06-2019, 05:38 PM
mukluk
mukluk's Avatar
At least on '04 through '06 models, the sixth digit of the VIN should be a number six for a Rubicon (ie, 1J4FA69Sxxxxxxxxx). Of course this only tells you what the Jeep was originally when it left the factory, only a visual inspection will reveal if it still has the front and rear Dana 44 axles, 241OR transfer case, and assorted pumps and switches it should have.
Becoming familiar with proper identification of drivetrain components would be a good idea; either that, or bring along a knowledgeable friend when looking at Jeeps.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #3 of 17 Old 01-06-2019, 07:10 PM
TripLeader
TripLeader's Avatar
A real (stock) Rubicon will have (in view):
Dana 44s in front and rear
Wider fender flares
Factory front and rear locker switch on dash
Decals on hood
Moab wheels
TripLeader is offline
post #4 of 17 Old 01-07-2019, 02:07 PM
GStauffeneker
GStauffeneker's Avatar
If I recall correctly, TJ Rubis all have factory lockers as well.
Greg Stauffeneker
2003 TJ Rubicon (Tomb Raider)
GStauffeneker is offline
post #5 of 17 Old 01-07-2019, 02:23 PM
TheBoogieman
Jeepaholic
TheBoogieman's Avatar
DON'T buy an 05-06 AUTO. Search it.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4.25" combo lift/Rancho 9000XL shocks/5.13 gears-35" MTZs/LoD bumpers
Desert Sand 99' XJ Classic (JEEP #18) ) 5" BDS lift / HP30/ 8.25/ 33x12.50" DC Extreme Country/Tactik black satin wheels.
TheBoogieman is online now
post #6 of 17 Old 01-07-2019, 02:26 PM
TheBoogieman
Jeepaholic
Rubicon - 2003-2006
* 4.0L I-6 engine
* Tru-Lok selectable pneumatic lockers, activate in 4-lo and under 10mph, engaged until out of 4-lo or deselected
* Limited slip rear when unlocked
* NV241 Rock-Trac 4:1 transfer case -- fixed yoke
* Heavy-duty driveshafts with 1330 u-joints
* Dana 44 front and rear axles
* 4.10 gears
* Goodyear Wrangler MT/R LT245/75R16 (30.5"x9.6") Tires
* 16x8, five-spoke aluminum wheels
* Diamond plate rocker guards
* Rubicon Lettering on Hood
* Flares are 1" wider than standard TJ flares
* 4-wheel Disc Brakes
Freeagent27 likes this.
post #7 of 17 Old 01-07-2019, 03:04 PM
Alaska-HWY JK
Donít be like that.
Iím fixing my PCM problem.
TheBoogieman likes this.
Alaska-HWY JK is offline
post #8 of 17 Old 01-07-2019, 03:06 PM
Alaska-HWY JK
No more Chrysler PCM problems.
TheBoogieman and Freeagent27 like this.
post #9 of 17 Old 01-07-2019, 05:08 PM
rcroane
How many Wranglers were manufactured in Ď05 - Ď06? How many have reported problems that warrant this recommendation not to buy? I wouldnít base the decision on the small percentage who have reported problems on this forum. The many owners without problems donít post.
rcroane is offline
post #10 of 17 Old 01-07-2019, 06:13 PM
getrdone
In addition to the Dana 44s front & rear the Rubicon also comes with a larger NP241 transfer case, vs the smaller diameter 231 on the standard model TJ.
getrdone is offline
post #11 of 17 Old 01-08-2019, 12:17 AM
TheBoogieman
Jeepaholic
It's not a problem until it's YOUR problem.
post #12 of 17 Old 01-08-2019, 08:18 AM
biffgnar
biffgnar's Avatar
Ronald Reagan once said it's a recession when your neighbor loses his job, but a depression when you lose yours.
mukluk likes this.
biffgnar is offline
post #13 of 17 Old 01-08-2019, 09:26 AM
rcroane
Yeah....I'm probably still in the denial phase.
Normally, I would just send my PCM off to ModuleGods and have them fix it. But, I jumped the gun and bought a Chrysler re-manufactured unit and I'm still having issues. Getting my transmission range sensor replaced as I write this. If that doesn't help, I'll start the warranty process for my Chrysler unit (I'd rather just get my money back, but I don't think they'll do that).
rcroane is offline
post #14 of 17 Old 01-08-2019, 10:04 AM
TheBoogieman
Jeepaholic
So true. I'm one of the few of both.
post #15 of 17 Old 01-08-2019, 10:27 AM
Alaska-HWY JK
I got two remanufactured Chrysler PCMs that didnít work. 4 O2 sensor codes with both. They sent my original PCM back so who knows where it went but let me keep the reman and gave me my money back. $1300
