TJ's with 2.5 over 100k. Am I buying problems - JeepForum.com
post #1 of 19 Old 11-18-2009, 02:47 PM Thread Starter
Sailor
I owned a 1995 YJ in the past but don't know much about the TJ's. What are the high mileage TJ's with 125k plus miles worth, if the body is in good shape and the frame is not rusted to heavy? Anything that I should be looking for on the TJ's ? Is the running gear about gone with that mileage on it? I am looking for a stock TJ with 2.5 4 cylinder. I had the 2.5 in my YJ but it was a low mileage Jeep with only 37k when I bought it, so it was trouble free for most of the time I owned it. Any advise would be appreciated.
Thanks
Sailor is offline
post #2 of 19 Old 11-18-2009, 07:34 PM
greggus
greggus's Avatar
My 97 TJ has 109k on it and no problems with the clutch or gears--the 4x4 light on dash is out but all the shifting works good---and adding, my YJ's engine died at 103k and the clutch went soon after--I love the ride and handeling of the TJ more but I miss the YJ, BUY WHAT YOU FEEL!!!--- In the end, something will go wrong (it is a JEEP) and will be fixed.
1997 Wrangler
Northern Michigan
OlllllllO
greggus is offline
post #3 of 19 Old 11-18-2009, 07:43 PM
superslayer
I'm up to 135K on my 4 banger and it's still running very strong, it doesn't eat a drop of oil either. As long as you keep it maintained it should run for a good long time.
superslayer is offline
post #4 of 19 Old 11-18-2009, 07:45 PM
jackel18
jackel18's Avatar
I bought my 99 wit 179,xxx on the clock. She has 182,xxx now, shes a little tired but she gets the job done. I wouldn't pay too much for it, but i wouldn't stay away because of the milage.
^ that was my name
jackel18 is offline
post #5 of 19 Old 11-18-2009, 07:48 PM
jdub2k5
bought my 4.0 at 109 didnt think twice about miles these engines run forever
also higher miles = better price
I was looking at 160-180k they all ran like new
2004 TJ 4.0 5 speed, 2 inch body lift, barricade armor, 4.5 bds lift, 35 mtz, sye, and tons more
jdub2k5 is offline
post #6 of 19 Old 11-18-2009, 07:55 PM
little_Jeep
little_Jeep's Avatar
After 100,000 miles, the 2.5L gets tired. Will it last 125,000, 150,000, or more? Who knows, but history says you are on barrowed time with the 2.5L at 150,000. The 4.0L has no problems with 200,000 plus miles.
little_Jeep is offline
post #7 of 19 Old 11-18-2009, 07:57 PM
jdub2k5
the 2.4 is using the neon engine right?
so that means parts are also modable
jdub2k5 is offline
post #8 of 19 Old 11-18-2009, 07:59 PM
greggus
greggus's Avatar
The 2.5 will last with forever-- I use high milage oil and it runs like its new--but if I had my pick i'd take a 4.0
1997 Wrangler
Northern Michigan
OlllllllO
greggus is offline
post #9 of 19 Old 11-18-2009, 08:29 PM
little_Jeep
Common mods to a 2.5L involve a V-8
post #10 of 19 Old 11-18-2009, 08:35 PM
turtlerace
Best taken in small doses
turtlerace's Avatar
1979 J-Series Truck
The 2.5 is just as reliable as the 4.0. Excellent, tough engines!
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you.
turtlerace is offline
post #11 of 19 Old 11-18-2009, 08:52 PM
LJameson
LJameson's Avatar
More of the minivan/liberty/larger car engine. The 2.4 wasn't used in a regular Neon, but the SRT4 uses a toughened up version of it.
Funny how we ***** about the JK having a minivan engine when TJ's had them too.
1976 CJ7 Restoration:
LJameson is offline
post #12 of 19 Old 11-18-2009, 08:55 PM
LuckRider
LuckRider's Avatar
There is nothing wrong with the 2.4. My sister's friend sold his 97 with 200k for $4k. Still running like a champ, no oil problems or anything.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #13 of 19 Old 11-18-2009, 08:56 PM
jeepwrangler97
jeepwrangler97's Avatar
I just took my 2.5L out with 160,000 on it, it ran great when I took it out, I only took it out to put a stroker in.
jeepwrangler97 is offline
post #14 of 19 Old 11-18-2009, 09:12 PM
jdub2k5
yes but the 3.8v6 mustang had the same liter as a jk and we all laughed at it
jdub2k5 is offline
post #15 of 19 Old 11-19-2009, 06:39 AM
superslayer
The 2.5 is essentially AMC 4.2L design with 2 cylinders cut off from it.
100k TJ GSU_DAVE TJ Wrangler Technical Forum 6 05-24-2009 02:34 PM
Frusterating problems with 97' TJ's softop ! vineswingman TJ Wrangler Technical Forum 2 02-24-2007 12:52 PM
common problems in newer tj's? Slaughter TJ Wrangler Technical Forum 70 06-15-2006 11:18 AM
just hit 100k!!! Nymisus YJ Wrangler Technical Forum 18 02-13-2004 10:51 AM
100K Not to bad. TexasJeepin' TJ Wrangler Technical Forum 17 07-19-2002 08:18 AM
