TJ rear axle leak - JeepForum.com
 4Likes
post #1 of 24 Old 07-04-2020, 08:24 AM Thread Starter
tropicalwj
TJ rear axle leak
Hi everyone, the rear axle on my TJ is leaking. Attached a picture. Going to ask a mechanic to fix. Is it a hard job? Is it ok to drive it 30 miles to the mechanic?
Really appreciate your knowledge!
tropicalwj is offline
post #2 of 24 Old 07-04-2020, 08:39 AM
bobjp
It is ok to drive it so long as it hasn't lost a lot of oil. Pull the plug and see how high it is. It is the pinion seal that has failed, and it is not that difficult to fix.
97 TJ sport.
bobjp is offline
post #3 of 24 Old 07-04-2020, 10:33 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
What axle is that? Cover and bolts look strange.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
GOT IT BACK 6/17. 03' Rubicon/Zone 4.25" combo lift with 4" lift coils up front/Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
TheBoogieman is offline
post #4 of 24 Old 07-04-2020, 10:35 AM
TheBoogieman
Distubed Jeepaholic
Are you sure? My limited eyesight didn't see the drip down to the diff cover. I was thinking the strange cover itself.
post #5 of 24 Old 07-04-2020, 10:44 AM
bobjp
Maybe it is just the cover. The bottom of the housing looks kind of wet to me, and it seems to be the more common leak point.
TheBoogieman likes this.
97 TJ sport.
bobjp is offline
post #6 of 24 Old 07-04-2020, 11:22 AM Thread Starter
tropicalwj
Thanks guys! Some more pics attached. Is the diff cover weird? Any more thoughts on the cause and fix? This is the rear axle. Thanks!
20200704_130633_1593883166932.jpg   20200704_130706_1593883212303.jpg   20200704_130748_1593883329227.jpg   20200704_130816_1593883354536.jpg   20200704_130859_1593883382285.jpg
post #7 of 24 Old 07-04-2020, 11:38 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That leak looks more like it's coming from the cover not the pinion seal. That's not a difficult job to reseal it, you don't even need a gasket. Mopar RTV, Permatex Gear Oil RTV, or Permatex Ultra-Black RTV (in that order) are good ways to seal it. Some like the Lubelocker gasket but I have mixed feelings with them after several uses of them over the years.
I would however replace those allen-head bolts with standard 5/16x18x9/16 hex-head bolts. The allen-heads have a nasty habit of stripping out since those bolts aren't very high quality.
NashvilleTJ likes this.
Jerry Bransford is offline
post #8 of 24 Old 07-04-2020, 12:20 PM Thread Starter
tropicalwj
Thanks!
post #9 of 24 Old 07-04-2020, 12:30 PM
2jhanna
And if you don't do offloads or play in the rocks, I'd ditch the rear cover shield.
oh, and D44, which I find odd with those wheels/tires. normally I would think if the factory installed a d44, you'd get the 30" tire/wheel package. unless diff was swapped out.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #10 of 24 Old 07-04-2020, 06:14 PM
WallyDog1
WallyDog1's Avatar
It's a 30 it has drum brakes. I seem to remember reading some place the Sport was given a 44 in some cases. It's considered a base Jeep though. Pretty sure though that all 44's had disc brakes...right?
From the Smoky Mountains of Western North Carolina
WallyDog1 is offline
post #11 of 24 Old 07-04-2020, 06:23 PM
bobjp
The early TJ's had the D44 as an option and they had drum brakes.
Jerry Bransford likes this.
97 TJ sport.
bobjp is offline
post #12 of 24 Old 07-04-2020, 06:43 PM
2jhanna
the diff picture with the leak, is in the rear. It should either be a 35 or 44. based on its shape and fill plug, its a 44.
and yes, many rear 44s did come with drum brakes, including mine.
jhanna
denton county, tx
2jhanna is offline
post #13 of 24 Old 07-04-2020, 07:10 PM
mukluk
mukluk's Avatar
The Jeep in question is RHD. A fuzzy memory that comes to mind was that all models of RHD TJ, at least those in the European market, had the rear D44 fitted.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #14 of 24 Old 07-04-2020, 07:19 PM
2jhanna
Good catch on the RHD, I didn't pick up on that.
And, yep, that probably does explain my being odd comment.
jhanna
denton county, tx
2jhanna is offline
post #15 of 24 Old 07-04-2020, 08:50 PM
mukluk
mukluk's Avatar
I didn't catch the RHD at first either, then the track bar bracket immediately right of the differential caught my eye.
Also seems a bit odd to me to see a full set of adjustable control arms fitted to a Jeep with a stock slip yoke driveshaft and sitting at or near to stock ride height.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
