tj frame rot - JeepForum.com
post #1 of 8 Old 11-12-2013, 11:27 AM Thread Starter
fourbanger97
tj frame rot
any ideas to repair frame besides a swap?
fourbanger97 is offline
post #2 of 8 Old 11-12-2013, 11:28 AM
Ironhead
Ironhead's Avatar
lots of options, depending on how bad it is...pics?
upload some pics to photobucket or a similar site and paste the img tag in here
Ironhead is offline
post #3 of 8 Old 11-12-2013, 11:38 AM Thread Starter
fourbanger97
its really bad the whole rear end rotted out from the control arms back. i cut the back out of a tj in the junk yard my dads buddy said he could weld the section to my frame. not to sure how that will go
post #4 of 8 Old 11-12-2013, 11:43 AM
srlbotanical
srlbotanical's Avatar
its really bad the whole *** end rotted out from the control arms back. i cut the back out of a tj in the junk yard my dads buddy said he could weld the section to my frame. not to sure how that will go
What other ideas are you looking for? If you've got the skills, replacing the back half of the frame with another frame section is an option, but if the frame is that bad, I'd be looking at the bottom skid mount area as well. I bet it's not far behind. A frame swap is really not any more work than welding up a back half in my opinion.
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
post #5 of 8 Old 11-12-2013, 11:53 AM Thread Starter
fourbanger97
i checked the rest of the frame is solid i couldnt find a cheap frame in nice shape. i got the rear section for $40.
post #6 of 8 Old 11-12-2013, 11:47 PM
2003RubiBlue
Hate to say it, but rarely if ever have I seen a frame where the back was real bad and the rest was fine, as srlbotanical said check under the skid plate on the bottom of the frame rails, that is where a lot of problems come from, however if it is confined to that area AutoRust makes a nice pre made weld in replacement piece that I have used with some success on frames with issues. If you think you can fix the frame you have I say go for it, but just be warned you will probably find more rot the further you get into it. I have spent some time in PA and I have seen the way PENNDOT lays down road salt. Thats all im sayin',
Brian
Will work for Jeep parts...
2003RubiBlue is offline
post #7 of 8 Old 11-13-2013, 07:31 AM Thread Starter
fourbanger97
it is just the rear half i did my research and didn't find any other roy on the frame i will look farther into the skid plate area but from what i see it looks all good
post #8 of 8 Old 11-13-2013, 12:04 PM
06philaTJ
Only way to really tell is to unbolt the transfer case skid. Every TJ in this area from what I've seen has surface rust/crustiness in the gap where the driver's side of the transfer case skid bolts to the frame. Low mileage, high mileage, and age don't matter, they all do especially if they were driven in the winters of 2009-2011.
The problem is it'll look like "just minor surface rust" bolted up but once you drop that skid, you might not like what you find since the skid hides alot of frame rot easily. It'd be best to throughly check it because if your luckily, it's already been repaired by the PO so welding in the new sections in the rear of the frame would be worthwhile. If it hasn't, it'll save you from wasting time/money/effort on a frame that's already too far gone.
BTW, on another note, there is a guy in West Chester that has clean frames/tubs on Craigslist and there is Davey's Jeep not too far from for sourcing clean frames/tubs as well if do go the frame-swap route.
06philaTJ is offline
