tj exhaust pipe size? - Page 2 - JeepForum.com
 4Likes
post #16 of 26 Old 04-28-2015, 03:46 PM
GringoLoco
GringoLoco's Avatar
Originally Posted by 26679cj5 View Post
Hey Matt, how come the fitment on the Flowmaster y-pipe for 2000 model TJ's is so terrible? It hangs way lower than the factory unit, which causes interference with oil pan skids, and the bends dont hug the oil pan any where near as tight. Once it curves around and goes down the side of the engine, it is almost right up against the passenger side upper control arm bracket.
It's the same with the Magnaflow y-pipe. My Magnaflow ended up sitting about 1/8" below my right side UCA, ended up having about 1/2" of downtravel before it hit. Had to take it to a shop and have them cut a section out and reweld it. I'm sure when I get some underarmor I'll be right back cutting it up again. Don't know why, but it seems pretty much all the manufacturers have trouble making a replacement pipe to the same dimensions as stock.
YELLOW Jeep Club Member #5606
13 mpg - edit: 12 mpg
No hi-lift on the hood (yet)
Odd noises
Still can't get it to take off from a treadmill....
GringoLoco is offline
post #17 of 26 Old 04-28-2015, 08:45 PM
26679cj5
26679cj5's Avatar
Originally Posted by [email protected] View Post
Which part number are you running?
Well this is really sad.....but I have a magnaflow and not a flowmaster....whoops.
26679cj5 is offline
post #18 of 26 Old 04-29-2015, 03:43 PM
FlowmasterMufflers
FlowmasterMufflers's Avatar
No big deal. I was asking which part # you were running because we don't produce a direct-fit Y-pipe for the TJ.
FlowmasterMufflers is offline
post #19 of 26 Old 04-17-2019, 11:35 AM
intheair
intheair's Avatar
1975
sometimes simple questions have unexpected variables, changes made mid year during a production run, or modifications or new ways of addressing a situation that might be cheaper, better, or simpler. Does one want inexpensive, get it back on the road; best performance; or a solution that is close to stock as possible. Searches can be difficult sometimes - finding the right key words, etc.
intheair
intheair is offline
post #20 of 26 Old 04-17-2019, 01:40 PM
Andy-WhiteTJ
You realize this thread is 4 years old, right?
1998 White TJ with a whole lotta stuff...
Just another member of:
(a 501(c)(7) Not-for-Profit Corporation)
Member:
(Northeast Off-road Vehicle Alliance)
Andy-WhiteTJ is offline
post #21 of 26 Old 04-18-2019, 08:39 AM
intheair
intheair's Avatar
1975
Yes but My computer is 6 years old and my wine cellar has a number of 5 year old selections - my 74&75 CJs are quite old too. Of course they could delete old threads - This reminds me of a battle I fought in the Boar War.....
intheair
intheair is offline
post #22 of 26 Old 04-18-2019, 08:01 PM
Pine_Cat
Pine_Cat's Avatar
Use the search function: it's Boer War
2017 JK
2016 MK- Murchison springs, ~1" BL, skinny 30s
2011 KK- H&R lift springs, OldManEmu shocks/struts, skinny 31s
2009 Sorento- H&R springs, ToyTec strut spacers, OldManEmu shocks/struts, 31s
2006 TJ budget LCG prerunner- see profile
2006 Trailblazer- EXT lift, Nth LJ 4.5" springs + Monroe rear coilovers, skinny 32s
1998 Durango- SuspMax & Roadmaster lifts, rear Truetrac, skinny 32s
Pine_Cat is offline
post #23 of 26 Old 04-19-2019, 06:44 PM
mukluk
mukluk's Avatar
But is it the First or Second Boer War?
Pine_Cat likes this.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #24 of 26 Old 04-22-2019, 07:33 PM
RogerP
But what if he was fighting pigs???
RogerP is offline
post #25 of 26 Old 04-23-2019, 04:15 AM
Kiwi_TJ
2.5 - 2.23"
On my 1997 TJ the exhaust is 2.5" from the engine to the cat then 2.25 from the muffler to the end of the tail pipe.
I have just fabricated up a new mandrel bent 2.25" pipe from the muffler to the end of the tailpipe. The stock tail pipe necks down to about 1.9" at the bends, so my new on should be better.
( I made the new tailpipe to clear some space for my new suspension system.)
Hope that helps
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
post #26 of 26 Old 04-23-2019, 08:28 PM
Pine_Cat
Pine_Cat's Avatar
Reminds me of the Cubans who had their Florida real estate taken away from them by the Clinton administration in the late 1990s, at 10 cents on the dollar. "I come from a pig country! I didn't know this is pig country, too," etc., etc., . . .
That kind of **** can swing close elections, at least in Florida.
I don't miss that kind of action - I only miss the clarity
2017 JK
Pine_Cat is offline
tj , wrangler , exhaust , pipe , size , help
YJ 4.0L exhaust pipe size skidawgz YJ Wrangler Technical Forum 7 03-23-2010 12:34 AM
Exhaust pipe size?? jeepbronco1 JK Wrangler Technical Forum 2 09-19-2009 08:55 PM
Exhaust Pipe Size SupermanTJ TJ Wrangler Technical Forum 1 02-26-2009 04:31 PM
Exhaust Pipe Size help please dirtysilver06 TJ Wrangler Technical Forum 2 03-22-2008 06:17 PM
exhaust pipe size rmnkys TJ Wrangler Technical Forum 0 05-03-2004 03:14 PM
