TJ Dash Light Wiring Schematic? - JeepForum.com
post #1 of 3 Old 12-29-2008, 10:26 AM Thread Starter
CJnaTJ
A little over a month ago, my rear wiper switch imploded on itself and took my dashlights with it. I have replaced the rear wiper switch, but my dash lights are still fubar. I've been putting off wire-chasing because it's been so blooming cold lately, but we're looking at a week of almost-above-freezing temps, so I thought I would take this 'heat wave' as an opportunity to try to fix the dash lights.
I have checked ALL fuses, etc. and have come to the conclusion that there must be a wire fried between the fuse block and the lights themselves. I'm looking for a wiring schematic that includes the dash lights and switch so I know which wires to check.
FYI: 03 TJ-X
Thanks for any help..
CJ
Blue 2003 TJ X
4" lift; 33x12.50 KM2s; front LockRight
CJnaTJ is offline
post #2 of 3 Old 12-29-2008, 10:30 AM
badassjeep04
https://www.jeepforum.com/forum/showthread.php?t=652960
for the time being these should help you out, ill PM u the FSM later when i get home.. these should help you though.
I still havent figured my problem out yet si i puchased a new guage cluster. you said that the wiper switch might of damaged the dash lights? is this for the front or rear wiper. let me know because this might help my problem
badassjeep04 is offline
post #3 of 3 Old 12-29-2008, 12:28 PM Thread Starter
CJnaTJ
Wow. That's some pretty in-depth diagnosis. I'm not looking forward to getting into it as much as I was before. I hate fighting electrical problems.
My rear wiper switch is the one that fried. I went to turn the wiper on one day and it didn't have any kind of detent in it - it flopped loosely. I caught a whiff of burning/hot plastic immediately after that. I felt around looking and waiting for flames, but never saw anything. I pulled the switch out and the internal guts of the wiper switch itself had imploded on itself. Ever since then, my dash lights have not worked. I replaced the rear wiper switch, and the wiper & washer both work fine, but my dash lights still don't work.
Blue 2003 TJ X
CJnaTJ is offline
dash light wiring/what's best? traumajunkey YJ Wrangler Technical Forum 0 03-21-2009 10:19 AM
DASH LIGHT wiring badassjeep04 TJ Wrangler Technical Forum 2 12-06-2008 01:40 PM
Under Dash Wire Schematic the_ronster TJ Wrangler Technical Forum 3 12-23-2006 11:30 PM
OEM Fog Light Wiring Schematic Jeep_Maniac TJ Wrangler Technical Forum 4 10-01-2005 12:42 PM
dash lights wiring schematic? hmk_21 YJ Wrangler Technical Forum 1 02-16-2005 05:02 PM
