TJ 97 2.5 engine swap - JeepForum.com
post #1 of 6 Old 01-24-2016, 04:19 PM Thread Starter
LoveRjeep
We have a 97 TJ 2.5 and want to swap the engine from our old 96 XJ 4.0 HO. Any advice or knowledge on this possibility?
LoveRjeep is offline
post #2 of 6 Old 01-24-2016, 07:09 PM
lander2312
I looked into this swap a few months ago and it just didn't seem worth it. To go through the whole deal of the swap you should just do the Chevy small block swap. 30lbs difference in weight yet a lot more HP and torque. Same amount if work. In tje end it wasn't worth the effort so I will ride my 2.5 till it dies. Most recommend selling the jeep and buying a 4.0 Jeep from the factory.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
George Orwell
lander2312 is offline
post #3 of 6 Old 01-24-2016, 07:11 PM
lander2312
Oh and if you havnt re-geared...do it. I went from factory 4.10 to 4.88. Breathing I ever did. Only regret was not going 5.13....lol
George Orwell
post #4 of 6 Old 01-24-2016, 08:30 PM
Mousejockey
Possible? Yes
Worth it? Depends on why your making the swap.
Motor mount brackets need cut off the frame and moved, electrical needs to be converted/spliced, emission laws need to be with
What are the reasons for the swap ? What are your goals?
Mousejockey is offline
post #5 of 6 Old 01-24-2016, 08:56 PM
rda616
rda616's Avatar
The small block Chevy was popular in old CJ and YJ wranglers, but not really in the TJ. An LS motor is a fairly popular swap, but costly vs a magnum V8 which is the cheapest and easiest swap. My next V8 I swap into a wrangler will be a hemi.
rda616 is offline
post #6 of 6 Old 01-24-2016, 08:58 PM
rda616
rda616's Avatar
You will need quite a few things to do this swap and it would be easier to do if the donor was a 97 TJ.
rda616 is offline
