Tj 8.8 Swap - JeepForum.com
post #1 of 9 Old 04-18-2018, 01:39 PM Thread Starter
champbing02
Tj 8.8 Swap
Alright, so I got a wild hair and thought that I could swap in an 8.8 for my dana 35 in the rear. I am about halfway through my project and I am having some concerns.
1. When I weld up all the mounts and mock it all up if my measurements are off a little bit whats going to happen?
2. If it is going to cause problems my solution was to do adjustable control arms.
3. If I do adjustable control arms am I going to have to do uppers and lowers or just lowers?
4. Also if I did control arms I was going to build them myself that way I would have the rod ends to reuse if I ever went to long arms.
Any and all help is appreciated!!
Jeep info
2-inch coil lift currently
on 31s
stock control arms and no adjustable track bars yet
champbing02 is offline
post #2 of 9 Old 04-18-2018, 03:11 PM
mikepelchy
If your mounts are off by too much, your rear end won't track straight and you could experience vibration from having an incorrect pinion angle. Your best would be to get the brackets tacked into place and them mount everything up and double-triple measure all of your brackets and angles and verify that everything is okay and there are no interference issues when either side of the axle travels up/down. Something else to think about/take into consideration, the 8.8 is a little narrower than the D35. I would suggest using a digital angle finder to help get everything dialed in. I only had adjustable uppers and I was able to get everything to work out pretty well.
I know that when I did my 8.8 swap a while back, I had issues with the diff cover coming in contact with the skid plate for the fuel tank, but it was an after market side plate and a pretty thick diff cover. This is where taking the time to mount in the jeep before welding everything solid really would have helped.
mikepelchy is offline
post #3 of 9 Old 04-18-2018, 08:28 PM Thread Starter
champbing02
Planned on tacking the brackets and mocking everything up. Did you have the adjustable arms before the swap or got them as a result of the swap?
post #4 of 9 Old 04-18-2018, 09:10 PM
mikepelchy
I had them before to help correct my pinion angle with the lift kit.
post #5 of 9 Old 04-19-2018, 07:11 AM Thread Starter
champbing02
When you did your swap what did you do for wheel spacers to correct this?
post #6 of 9 Old 04-19-2018, 08:13 AM
BM3
BM3's Avatar
This link might answer some of your questions http://www.wranglerforum.com/f210/ar...wap-92569.html
BM3 is offline
post #7 of 9 Old 04-19-2018, 09:36 AM
Gary2
2012 TJ Wrangler
I use 1/4" wheel spacers on mine. It gives back some of the width and cost next to nothing. Been running them for the better part of ten years with out an issue
Gary2 is offline
post #8 of 9 Old 04-24-2018, 08:15 AM
mikepelchy
Nothing. I believe the width difference was 5/8", so about about 5/16" on each side. I never noticed any issues.
post #9 of 9 Old 04-24-2018, 09:13 AM
TheBoogieman
Coronavirus survivor!
TheBoogieman's Avatar
Read my sig. Both are true.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/Black Magic brakes. ***SOLD*** for Covid-19 pandemic rent money. :(
99' XJ /4.0L-AW4/ 5.5" lift / Rancho RS5000X shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
8.8 , control arms , dana 35 , ford 8.8 , swap
