Tj 4 inch lift - JeepForum.com
post #1 of 9 Old 09-21-2010, 05:20 PM Thread Starter
connorp213
Tj 4 inch lift
So I just bought a 4 inch skyjacker short arm suspension lift, Ive had a jeep for a while but the whole lifting is a new world to me, I know I have to change the brake lines since i went 4 inches but am i going to have to anything else?, also I want to put 33x 12.5s on my tj and my gear ration is 3.73, will i have any issues? thanks help would be appreciated
connorp213 is offline
post #2 of 9 Old 10-06-2010, 03:01 AM Thread Starter
connorp213
no one has any suggestions/help?
post #3 of 9 Old 10-06-2010, 05:48 AM
TNeustadt
TNeustadt's Avatar
Do a search to see what others have had to do... but for starters, make sure to get the tracking correct. Either with trackbar relocation bracket or adjustable trackbar (in rear), and an adjustable in front.
TNeustadt is offline
post #4 of 9 Old 10-06-2010, 06:22 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
I've installed several of the RC lifts.You only need extended brake lines if you disconnect.RC 4" lift and 33's.
TheBoogieman is offline
post #5 of 9 Old 10-06-2010, 08:20 AM
conrasm
conrasm's Avatar
The 33 x 12.50's won't be horrible with the 3.73 gears. You may notice it some on the highway with hills and your gas mileage will go down. I've had 33 x 10.50's on my TJ with 3.73 gears and barely noticed it.
Are you planning on a heavy MT tire? That will affect your acceleration, mileage and braking more than a lighter tire.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #6 of 9 Old 10-06-2010, 09:44 AM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
Get some OEM length YJ front brake lines. Those will be 3" longer than TJ lines. You don't need a new rear brake line...
Gone but not forgotten.
Knuckelhead is offline
post #7 of 9 Old 10-07-2010, 01:33 PM Thread Starter
connorp213
thanks for the feedback, but what about the slip yoke eliminator and rear drive shaft?
post #8 of 9 Old 10-07-2010, 01:47 PM Thread Starter
connorp213
but i only have 3.73 gears, and dont i need to put a slip yoke eliminator and a cv driveshaft to balance out the dimensions?
post #9 of 9 Old 10-07-2010, 02:02 PM
Knuckelhead
R.I.P. Knuckelhead
With 4" of added suspention lift, yes. I would add the SYE and DC DS...
Two inch body lift= 2 Inch motor mount lift? TOLjeep TJ Wrangler Technical Forum 12 10-01-2011 10:36 AM
4 inch Suspension Lift 2 inch body = Slip Yoke/Driveshaft? ECUSAE20 TJ Wrangler Technical Forum 11 05-08-2009 11:12 PM
2003 rubicon: 1 inch body lift and 2 inch coil spacer lift. tire size? Bobski TJ Wrangler Technical Forum 6 10-05-2008 07:38 PM
Right rear tire extends inch farther out than left after 2 inch lift. blang158 TJ Wrangler Technical Forum 9 07-05-2006 01:15 PM
1.5 inch spacer and i inch body lift is this a good lift? magnum629 TJ Wrangler Technical Forum 7 02-11-2006 11:16 AM
