tire size question - JeepForum.com
post #1 of 9 Old 07-30-2007, 08:32 PM Thread Starter
jpbellis
tire size question
I have the oem wrangler tires on my stock unlimited. Whats the largest tire the stock 15x8 rims can hold?
jpbellis is offline
post #2 of 9 Old 07-30-2007, 08:34 PM
Rocky529
Rocky529's Avatar
They can hold a 35x12.5" tire.. it is what your stock Jeep can handle. 31x10.5" is the biggest you should go on stock suspension.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 9 Old 07-30-2007, 08:36 PM
MerkurXR4Ti
Sorry, I have no answer, but a similar question...
Anyone who can help you can help me, I have a 98 sport 4.0 with 30 inch optional tires (I think the wheels are 15x9.5 according to tire rack), what size of 31's can I get? No one I can find makes 31x9.5-15s.
MerkurXR4Ti is offline
post #4 of 9 Old 07-30-2007, 08:39 PM
Rocky529
Rocky529's Avatar
15x8" wheels most likely... and you can get 31x10.5" tires without any rubbing issues.
You MAY get some rubbing at full lock however, not usually, but if you do... you can add a couple of washers to your steering stops. It takes 5 minutes and you can find out how to do it here if you have to do it (you probably won't).
Rocky529 is offline
post #5 of 9 Old 07-30-2007, 08:40 PM
MerkurXR4Ti
Can I get 31x10.5"s on stock wheels?
post #6 of 9 Old 07-30-2007, 08:42 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
yes. you dont want a tire thats the same width as your rim.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #7 of 9 Old 07-30-2007, 08:43 PM
MerkurXR4Ti
great thank you!
post #8 of 9 Old 07-30-2007, 08:56 PM
arbby
2005 KJ Liberty
A tire that is the same width as the wheel won seat and therefore be useless. I dont even know it it could make it on the road...
|l,[___],
l---L--OlllllllO
()_) ()_)--o-)_)
Gone: 1993 YJ
arbby is offline
post #9 of 9 Old 07-30-2007, 09:00 PM
omgsideburns
where did you hear that?
i know guys who run tires narrower than the rim..
omgsideburns is offline
Another Tire Size Question NCUNLIMITED TJ Wrangler Technical Forum 12 11-24-2009 11:06 AM
Tire Size Question (Not about maz size) Mike318_ YJ Wrangler Technical Forum 5 01-09-2009 02:51 PM
tire size question Jeepman85 TJ Wrangler Technical Forum 2 07-08-2007 05:20 PM
Question on tire size??? BigNunz6 TJ Wrangler Technical Forum 10 12-29-2006 09:36 PM
Another Tire Fit Question. Real Tire Size? Gene K YJ Wrangler Technical Forum 2 04-06-2003 08:37 PM
