Tire fell off going down the road.. Wheel spacer failure? - JeepForum.com
 2Likes
post #1 of 106 Old 06-19-2010, 05:56 PM Thread Starter
Osmosiz
Osmosiz's Avatar
1973 FSJ Wagoneer
So im driving down the road and the jeep starts going all over the place like death wobble, and i look out the window and my tire is wobbling like crazy and lugnuts are flying off ...then the tire shoots off and goes flying into the woods about 100 feet down the road... meanwhile im going down the road at 40 with three tires, so i tap the brakes and she dives right, and goes off the road.. phew.. finally its over.. jeep is in the ditch, minus a tire.
Damage:
-put a flat spot on my brand new rotor
-wallowed out my wheel lug holes
- One of the lugs on my spacers is sheared right off.
Im not sure how this couldve happenned.. i just put on the WJ brakes conversion and torqued everything afterwards, i even double checked them on friday. everything was tight. .
Pics of spacer:
luckily it was just me and the dog in the jeep at the time, we are both fine just a little shell shocked. so could it be that the spacer failed which caused this chain of events to occur?
why else would the tire come off when i had just torqued all the bolts.. also it wallowed the heck out of my rim holes.. so they must have been tight. i am planning on calling the company to talk to someone.
2000 XJ
will work for jeep parts
Osmosiz is offline
post #2 of 106 Old 06-19-2010, 06:10 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Good that your ok! I know that feeling... when I had a few axles break on my old D35.That is one reason I have never cared for wheel spacers, period!
GOLENJEEPTJ is offline
post #3 of 106 Old 06-19-2010, 06:10 PM
jerseyjeep22
jesus thats pretty rough...if you torque'd everything to specs than idk
jerseyjeep22 is offline
post #4 of 106 Old 06-19-2010, 06:12 PM
bruteboy
it looks to me like the stud that broke was the only one that was tight and the others were loose
or came loose.
the lug holes in your rim will only wallow out if there is movement(ie loose nuts)
I don't see any failure of the spacer,only one broken stud and some wear from the loose wheel.
not sure about the cause.
bruteboy is offline
post #5 of 106 Old 06-19-2010, 06:15 PM Thread Starter
Osmosiz
Osmosiz's Avatar
1973 FSJ Wagoneer
could i put new studs in and reuse the body of the spacer for now? after this im buying some new wheels..
2000 XJ
Osmosiz is offline
post #6 of 106 Old 06-19-2010, 06:18 PM
tc90xj
1994 XJ Cherokee
You used the wrong kind of lugnuts for your wheel combination. The same thing happened on one of my rigs with spacers.
tc90xj is offline
post #7 of 106 Old 06-19-2010, 06:26 PM
ZeroGravity
ZeroGravity's Avatar
I probably wouldn't re use a part that catastrophically failed causing your tire to fall off.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #8 of 106 Old 06-19-2010, 06:30 PM
dwilliams35
Not sure what happened, but that toaster oven is SWEEETTT....
Kinda weird "shine" pattern on the remaining lugs: I'll go with the "only one tight" theory..
dwilliams35 is offline
post #9 of 106 Old 06-19-2010, 06:31 PM
SuperWade2
More Money than Brains
SuperWade2's Avatar
Makes me want to go check the torque on my Spidertrax spacers and rims...Glad your ok... Would be interested if you find out what led to failure!
2017 WK2 Overland
SuperWade2 is offline
post #10 of 106 Old 06-19-2010, 06:32 PM
Oatmealman
1987 YJ Wrangler
lol ditto.Could have possibly put the wrong lug nuts on(as stated before).Wheel spacers are bad news,I don't care who tells you their not,adding extra leverage on wheel bearings,ball joints,spindles, lug nuts and other things is not a good idea with wheels spacers,it's bound to fail.
87 yj,60,14b,39.5s,350,th350,203 part time conv, true duals,soa
Oatmealman is offline
post #11 of 106 Old 06-19-2010, 06:40 PM Thread Starter
Osmosiz
Osmosiz's Avatar
1973 FSJ Wagoneer
yea was rethinking that, def not using the old ones.. talked to the wife, im getting new rims for fathers day! still planning on contacting spidertrax though, i want to hear what they say... as far as lug nuts, i used the ones they supplied in the kit, and the stock ones for the wheel.
as far as only 1 being tight.. yea maybe they loosened, but they were tight on friday.. torqued them myself.
i wish i could go back and watch it in slow motion.. i would love to know what really happenned to it.
2000 XJ
Osmosiz is offline
post #12 of 106 Old 06-19-2010, 06:40 PM
a2tripp
a2tripp's Avatar
1993 XJ Cherokee
sounds like something my ex girlfriend did..........
93 cheromanche
a2tripp is offline
post #13 of 106 Old 06-19-2010, 06:56 PM
1CleanTJ
1CleanTJ's Avatar
my vote would be loose lugnuts. wallowed out holes would be a very good indication of that. maybe you did tightened them, maybe they wernt sitting flush, maybe someone loosened them up on you etc. If it were the wheel spacer, the wheel spacer would be bolted to the wheel off in the woods still
<-- CLICK !!! AND SHARE
1CleanTJ is offline
post #14 of 106 Old 06-19-2010, 07:07 PM
Lineleader
Lineleader's Avatar
My left rear wheel came off a few months ago doing about forty, scared the bejesus out of me. Still unsure of the cause, bu it did the same damage, wallowed out the wheel, smoothed out the rotor, tore the fender flair off and dented the rear panel.
Only thing we could come up with, was possibly some kids messing around the campground the night before, as I had spent the last two days wheeling.
Rest assured, i know check my lug nuts more often. interesting theory about possibly having the wrong lugnuts.
No wheel spacers.
'05 LJ 6 spd with 33 DC FC II on DC-1's, RE 3.5 SF, Superwinch Epi 9.0
Lineleader is offline
post #15 of 106 Old 06-19-2010, 07:11 PM
RubiconRazorbac
RubiconRazorbac's Avatar
What exactly did you torque the spacers and the lugnut to (how tight in ft/lbs)?
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
My wheel fell off on the highway. TheNewbie YJ Wrangler Technical Forum 39 04-02-2015 06:48 PM
wheel fell off jezow2010 TJ Wrangler Technical Forum 29 01-01-2010 12:06 PM
Front Spring Isolator (failure) + Spacer? KnightFire TJ Wrangler Technical Forum 5 10-15-2007 08:33 AM
BL/MML/Tire/Wheel Spacer recommendation TJAB TJ Wrangler Technical Forum 4 11-23-2006 07:55 PM
Wheel fell off??? daciuk55 YJ Wrangler Technical Forum 10 10-25-2006 04:44 PM
