tire air pressure on street - JeepForum.com
post #1 of 8 Old 03-22-2008, 01:20 PM Thread Starter
jimG16
I'm running 33X12.5 maxxis bighorns and I'm wondering at what tire pressure i should be running them at. I want the tires to last as long as possible and what PSI is best for that.
jimG16 is offline
post #2 of 8 Old 03-22-2008, 01:23 PM
BYuen
BYuen's Avatar
I usually run at 30 psi for the street (33x12.5). Even then, not all of the tread contacts the road.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #3 of 8 Old 03-22-2008, 01:25 PM Thread Starter
jimG16
Is that bad? I couldnt really see that being much of a problem, what about PSI offroad
jimG16 is offline
post #4 of 8 Old 03-22-2008, 01:30 PM
robncar
robncar's Avatar
One way is to do a "chalk test". My kids have the big sidewalk chalk, it works really well. You put a patch of chalk down in front of each tire, drive over it and look at the pattern. Once you have even tread contact, you're done. I run about 26-28PSI in my MT/R's on the street.
https://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #5 of 8 Old 03-22-2008, 01:30 PM
BYuen
BYuen's Avatar
No it's not bad at all since it is small enough to be negligible. Sometimes I'll do 28 for the street. Usually I've seen most people run from between 28-32 psi on the road with 33x12.5s.
As for airing down, I go down to 12-13 psi. Works very well and I've never had any issues
2001 White TJ Sport
BYuen is offline
post #6 of 8 Old 03-22-2008, 01:32 PM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
If you do the chalk test and let all the tread hit the road,your tires will be under inflated badly.(mine came out to be 16psi)I run 22psi for 35's and 26psi for 33's.Thats what Mickey Thompson Co.told me to run for my tires.
TheBoogieman is offline
post #7 of 8 Old 03-22-2008, 03:43 PM
1CleanTJ
1CleanTJ's Avatar
its going to depend alot on how heavy your jeep is (bumpers winch etc) and what tire your running. Some tires have very thick sidewalls and even when aired down to 12psi they barely even bulge out
<-- CLICK !!! AND SHARE
1CleanTJ is offline
post #8 of 8 Old 03-22-2008, 08:16 PM
BlueFlame
BlueFlame's Avatar
When you do the chalk test, the goal is NOT to get all the tread to contact the road.
With 35x12/50s I'd have to air down to about 8 lbs to get the entire tread width to contact pavement.
The goal is to get what tread that does contact the road to wear evenly. If the center wears off first, you're overinflated. etc.
BlueFlame is offline
TJ, 31's, What Street Tire Pressure? ryobi TJ Wrangler Technical Forum 10 07-20-2014 12:17 AM
36x13.5 R15's bias ply - Air pressure on street vs offroad. Whats safe? Dr_Jim Wrangler General Discussion 2 02-10-2010 12:56 PM
Air down pressure for the street? crashtom Wrangler General Discussion 9 11-25-2009 02:27 PM
Street Tire Pressure? Supertau TJ Wrangler Technical Forum 5 12-19-2007 07:15 PM
tire pressure for procomp mud terrains on street jbpdog TJ Wrangler Technical Forum 5 05-20-2007 12:28 PM
