Tips on solving Electroysis in Cooling System - JeepForum.com
 6Likes
  • 1 Post By dbbd1
  • 1 Post By Que89YJ
  • 1 Post By pwmac
  • 3 Post By TheBoogieman
post #1 of 9 Old 04-23-2019, 04:11 AM Thread Starter
Kiwi_TJ
Hi There,
I have just replaced my radiator, and the guy that looked at my old one said that it corroded out due to electrolysis in the cooling system. Sure enough, I put the new radiator on and put the ground of the multimeter on the battery negative and the positive probe in the water, and got 0.5 volt, even with the Jeep not running, similar with it running.
Any ideas where to look to start fault finding this?
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
post #2 of 9 Old 04-23-2019, 08:24 AM
dbbd1
dbbd1's Avatar
Couldn't you just run a ground wire to the radiator?
jjandascog likes this.
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #3 of 9 Old 04-23-2019, 09:16 AM
Que89YJ
You will always have potential in cooling. Water running through a block picks up metal and will leave potential there. If you run demineralized water it would only be short term. Grounding the rad would leave it a path and still allow current to flow. If you maintain the cooling system and flush it every 60k or so it will last longer then the Jeep. Maintenance is the key.
Newtons3 likes this.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #4 of 9 Old 04-23-2019, 09:24 AM
pwmac
Easy to solve the issue by changing the coolant on a regular basis. The coolant has the ingredients to prevent corrosion.
pwmac
Durango, CO
06 Rubicon, modified
pwmac is offline
post #5 of 9 Old 04-23-2019, 01:49 PM Thread Starter
Kiwi_TJ
I already have a ground wire directly to the radiator core, that did not help.
I flushed the cooling system and put new coolant, water pump and Mishimoto radiator in one year ago. That radiator corroded out, so trying to stop that happening again. So this does not line up with the advice that new coolant will solve the issue.
Any other ideas?
Kiwi_TJ is offline
post #6 of 9 Old 04-23-2019, 02:20 PM
jjandascog
Is there a material difference between the Mishimoto radiator and stock? I know the tanks on the stock are plastic and the mounting flanges seem to be steel as opposed to AL of the Mishimoto one. I would guess the Mishimoto is also made from cheap quality AL. Put all that together and the fact that the Mishimoto is all AL (and again probably cheaper quality than the stock one), the radiator itself could be the problem.
I assume the mechanic that told you your previous radiator dies of electrolysis knows what that looks like with AL, it will leave a white powder as the AL is sacrificed.
2004 Jeep TJ Sport, 4.0, Auto, 3.5 SL, 1.25" BL, BFG's cool mud jack across the hood
jjandascog is offline
post #7 of 9 Old 04-23-2019, 02:27 PM
Que89YJ
Aluminum rads don't corrode the same way coppers do. All radiator systems do corrode though. Maintain them and you won't have issues. Cast block and heads, copper core, electricity flowing all over the vehicle, corrosion happens.
Sent from my SM-G955U using Tapatalk
Fault codes:
No Start:
Que89YJ is offline
post #8 of 9 Old 04-23-2019, 09:57 PM
WSS
Graduate U-Tube Univ.
WSS's Avatar
Can you put some sacrificial anodes in the tank? Change them every month. Zinc would probably be best, it will attract the doodoo.
WSS
The family TJ build:
non stock CJ's:
My CJ5 Build:
WSS is offline
post #9 of 9 Old 04-23-2019, 10:47 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Use a oem Mopar radiator, flush system thoroughly, add proper coolant and don't worry about it. Mine has over 150,000 miles on it and no problems.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/Black Magic brakes.
99' XJ /4.0L-AW4/ 5.5" lift / Rancho RS5000X shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3864 10-19-2019 10:58 PM
Air in cooling system and temp fluctuations FlamingRain ZJ Grand Cherokee Forum 13 04-13-2019 10:37 PM
Forward Collision Warning / Brake Fluid Level Sensor magik235 WK2 Grand Cherokee Forum 5 01-31-2019 06:42 AM
'96 4.0 ZJ Cooling System Upgrades Hatsuwr ZJ Grand Cherokee Forum 11 10-15-2018 09:22 AM
03 WJ Cooling system troubleshooting jamesnmandy WJ Grand Cherokee Forum 20 01-07-2018 08:37 PM
