Tiicking on acceleration - JeepForum.com
post #1 of 8 Old 03-11-2013, 04:02 PM Thread Starter
peicherokee
I know there is a lot of threads out there none really resolve the issue, I was in looking at my engine bay today trying to tell where the ticking was coming from but since it only happens under load it was kinda hard I am not crazy with stuff under the hood but have this picture something looks like its missing, sorry if its obvious to other but I don't know what goes on the end of the pipe thanks for any help
THE MORE MUD THE BETTER
PEI JEEPERS MEMBER
peicherokee is offline
post #2 of 8 Old 03-11-2013, 05:40 PM Thread Starter
peicherokee
That tube on the left is it suppose to go somewhere ?? Help
PEI JEEPERS MEMBER
post #3 of 8 Old 03-12-2013, 01:58 PM Thread Starter
peicherokee
noone?
PEI JEEPERS MEMBER
post #4 of 8 Old 03-12-2013, 03:10 PM
jeepn012
jeepn012's Avatar
Is there any play in the exhaust where it bolts to the manifold? I know its a PITA, but try to tighten up those two bolts.
Could be a small exhaust leak.
1990 YJ - 96 to 03 My first. She will be missed.
2004 TJ - 03 to 11. Old Faithful. I will have another TJ one day.
2007 JKU - SOLD
2005 LJ - In the mail, hope I like it. Everybody's doin it, here is the build:
jeepn012 is offline
post #5 of 8 Old 03-12-2013, 03:12 PM Thread Starter
peicherokee
I will give it a shot, do you know if that pipe bye the heat shield is suppose to go anywhere? or is the picture even visible?
PEI JEEPERS MEMBER
post #6 of 8 Old 03-13-2013, 09:03 AM
jeepn012
jeepn012's Avatar
Yep, I can see the pictures.
I'm not 100% sure on that tube. I had a flexible duct on my 1990 4.2L that ran from the manifold to the air cleaner assembly. Maybe check that.
You'll have to find another 4 cyl TJ owner to answer this one.
2007 JKU - SOLD
jeepn012 is offline
post #7 of 8 Old 03-13-2013, 10:02 AM
calabrate2
calabrate2's Avatar
Could the injectors cause a rapid ticking upon initial start up
calabrate2 is offline
post #8 of 8 Old 03-13-2013, 10:41 AM
Gordon-0
The tube you are talking about is a "heat stove". It feeds warm air to the intake in the winter to help warm up faster. It is not connected to the exhaust, it just gathers the heat radiating from the manifold. Depending on year, they may not have used a heat stove in your jeep. They are fairly common in Carbureted engines and some TBI applications, but not in a multiport FI engine.
Either way that isn't the cause of the noise
Gordon-0 is offline
