Thumping when turning or shifting out of 2nd and 3rd - JeepForum.com
post #1 of 4 Old 08-13-2019, 09:22 PM Thread Starter
theflyinggazell
Hey guys, I started driving today and when im driving slow like out of my neighborhood and and to make a turn while accelerating im getting a loud thump in the back of the jeep. also when I accelerate out of 2nd or 3rd gear it feels like the car is slipping out of gear. im assuming it has something to do with the rear diff and the pinion seal has some oil on it but it doesn't seem to be leaking bad. any thoughts? the driveshaft also has very little play.
theflyinggazell is offline
post #2 of 4 Old 08-13-2019, 09:35 PM Thread Starter
theflyinggazell
forgot to mention its a 05 wrangler x 89k miles manual transmission
post #3 of 4 Old 08-16-2019, 11:49 AM
mukluk
mukluk's Avatar
The description has me thinking a possible problem with the rear differential spider gears. I'd remove the rear diff cover and inspect the internals for damage.
2000 TJ SE
2005 LJ Rubicon
mukluk is online now
post #4 of 4 Old 08-16-2019, 12:00 PM
TJnBC
The slipping out of gear is usually a symptom of a worn clutch on a manual.
The thumping when load is applied could be as simple as worn out control arm bushings, ujoint(s) or loose bolts on suspension, or as severe as spider gears / gears chipped as Mukluk says.
2006 LJR...the madness begins again
TJnBC is online now
