Throttle controllers - JeepForum.com
post #1 of 6 Old 09-11-2019, 11:15 PM Thread Starter
Cain5683
I have a 97 tj and im searching to get better gas mileage so im looking for a throttle controller to add anyone know what i can get.
Sent from my SM-N960U using Tapatalk
Cain5683 is offline
post #2 of 6 Old 09-12-2019, 05:04 AM
jtec
2014 JK Wrangler
WHAT do you get for MPG and what do you want?
A 20+ year old utility vehicle with 4WD, wrangler's legendary aerodynamics and gas mileage is a concern?
1st thought vehicle is STOCK and well maintained, operated for what it is - this ain't a prius.
If applicable shifted when upshift light comes on, no jack rabbit starts, limited stop and go traffic and hi speed interstate driving -
jtec is offline
post #3 of 6 Old 09-12-2019, 06:41 AM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
There's a sticky thread in the engine/drivetrain sub-forum that covers fuel mileage pretty thoroughly:
https://www.jeepforum.com/forum/f19/...-sucks-721394/
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #4 of 6 Old 09-14-2019, 02:34 AM
AjRagno
AjRagno's Avatar
I don't think you'll find any add-on that will improve fuel efficiency. TJs were never really designed to get good gas mileage but it can be relatively acceptable if you keep the tires inflated, the engine properly tuned, accelerate moderately, and keep it under 62 MPH.
You're consuming the most fuel while accelerating so don't bother trying to keep up with much more modern vehicles from a stop.
From a previously post, it looks like you are getting 11-13 MPG and the '97 TJ is rated at 13-16 MPG. Have you performed any maintenance, plugs, wires, 02 sensors? Is the engine operating at 210?
AjRagno is offline
post #5 of 6 Old 09-14-2019, 05:44 AM
SkylinesSuck
I want to know exactly what you think a "throttle controller" is.
'98 Sahara w/AX15 & 4.6L stroker, 2.5" OME lift, 32" BFG M/T's, 8.8 w/Detroit Trutracs & 4.10's F&R
SkylinesSuck is offline
post #6 of 6 Old 09-14-2019, 07:16 AM
jtec
2014 JK Wrangler
IIRC placed under gas pedal to control throttle, improve MPG, and high rpm .
jtec is offline
