Throttle body plate scraping walls - JeepForum.com
post #1 of 8 Old 07-18-2010, 09:59 AM Thread Starter
MikalCarbine
I cleaned my TB the other week and I started noticing a metal-metal crunching feeling in my throttle pedal so I took a look at my TB. Inside the plate is scraping against the throttle body wall just where the pin that the plate is connected to meets. Some metal shavings were present too and I'm worried about my engine sucking them into the cylinders. Anyone ever see this? Is there any way to replace just the nylon bushings the plate rides on or should I start looking for a new TB? I looked at some ones in Cherokees in the junker but they were in horrible conditition.
MikalCarbine is offline
post #2 of 8 Old 07-19-2010, 07:37 PM Thread Starter
MikalCarbine
Anyone?
post #3 of 8 Old 07-19-2010, 08:29 PM
TJnIT
TJnIT's Avatar
Did you remove the plate when you cleaned the TB? If so loosen the two torx screws enough so you are able to move the plate and reposition it so it does not scrape.
TJnIT is offline
post #4 of 8 Old 07-20-2010, 10:33 AM Thread Starter
MikalCarbine
Good question, I started to take the plate off then stopped because it was a PITA, maybe I'll check that... The scraping doesn't always occur, just at times, there is definitely some play on the tb plate pin though
post #5 of 8 Old 07-20-2010, 06:08 PM
TJnIT
TJnIT's Avatar
The reason it was a PITA to get the plate out is because the factory uses thread locking compound on the torx screws. I little play in the "pin" is acceptable.
TJnIT is offline
post #6 of 8 Old 07-20-2010, 06:18 PM
ZachAttack923
ZachAttack923's Avatar
any progress man, (btw its zach attack)
it may take a couple trys to get it right, take your tb off and set the throttle plate and turn it by hand till you get it centered and it does not rub anymore
2.5L Low Output #923
White Jeep Club #923
1997 Jeep Wrangler 2.5L AX-5 D30/35 4.10 gears
31in Wildcat A/T's
Originally Posted by j_niko View Post
I would be as nervous as a virgin on prom night if I had to drive that
ZachAttack923 is offline
post #7 of 8 Old 07-21-2010, 05:01 AM
Neil F.
There is no need to remove the plate (and I would not). You certantly can hold it open and clean with a rag and q-tips if you really want to get in there. As indicated, they are installed wit thread lock. That is important. If they loosen and come out, they of course will go right in the motor.
Neil F. is offline
post #8 of 8 Old 07-21-2010, 02:24 PM Thread Starter
MikalCarbine
Haha Zach, I knew it was you the moment I saw the avatar. The plate is in tight but the play exists on the pin that the plate rides on, apparently this is normal but I don't understand where the scraping came from
throttle body , plate
throttle body and throttle body spacer laxin15 TJ Wrangler Technical Forum 11 08-24-2009 02:47 PM
Throttle Down Kustoms Skid plate VTJay YJ Wrangler Technical Forum 0 04-21-2009 07:17 AM
2004 throttle 4/0 throttle body on 95 2.5? Ironworker709 YJ Wrangler Technical Forum 1 02-04-2009 02:30 AM
Throttle Body Brice014 TJ Wrangler Technical Forum 4 07-20-2007 04:50 PM
throttle cables on throttle body eep3 TJ Wrangler Technical Forum 6 10-03-2005 04:03 PM
