LinkBack | Thread Tools |
Things to do after a susp. lift?
Hey all,
First thread here, so hopefully I don't get shot down too quickly.
I am having some troubles finding some information.
I am doing a OME ZJ/LJ susp. lift w/ a SYE, CV drive shaft & Complete RE arms.
What are the things you should do after doing a suspension lift and bigger tires?
I can come up with doing a front end alignment, checking the caster(?), double making sure your bolts are torqued to spec and toe-in.
Can anyone shed any light on these things you should do to prevent DW/Drive line vibes etc?
Thanks!
Thanks!
Stock 2003 Jeep TJ - 'Intense Blue'
Bought the jeep in April, found JF in May...
First Mod in June.
Sponsored Links | |||
Distubed Jeepaholic
Adjust toe-in (alignment)to no more than 1/8" total.Make sure new larger tires are perfectly balanced.Make sure axles are centered by using an adjustable track bar or redrill stock track bar hole(rear track bar bracket for $18).
Tags |
suspension , lift , lj , wrangler , sye , cv , follow up , after , post , alignment |
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Jeep Forums | Replies | Last Post |
Which to do first? exchange body lift or put in 3 inch susp lift | wmeyer116 | TJ Wrangler Technical Forum | 2 | 07-15-2009 10:53 PM |
RC 2.5 susp lift w/ 1.25 body or 3.25 susp lift | scott33 | TJ Wrangler Technical Forum | 2 | 03-24-2009 10:27 AM |
Coil spacer lift /w OME 2.5" susp. lift? | BP88 | TJ Wrangler Technical Forum | 5 | 02-21-2009 04:54 AM |
How much susp. lift do you think this YJ has? | pitbullguiller | YJ Wrangler Technical Forum | 11 | 10-31-2008 01:22 PM |
SOA vs. Susp. lift | dejablu311 | YJ Wrangler Technical Forum | 15 | 01-10-2003 03:53 PM |
Posting Rules | |
