There's a hole in my transfer case! - Page 2 - JeepForum.com
post #16 of 52 Old 09-03-2014, 08:46 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
As said above, don't drive it. Your transfer case is working, spinning, and powering at least the rear axle whether you're in 2wd or 4x4.
Jerry Bransford is offline
post #17 of 52 Old 09-03-2014, 08:46 PM
J03_TJ
J03_TJ's Avatar
Okay, here's an approach for the risk takers. The bottom edge of the hole looks like it half way between the fill hole and the drain hole. On flat ground fill it up through the fill hole until it starts seeping out of the added hole. That should be about a topped off as your going to get it. Since it's already toast and you might not care about collateral damage. I am thinking worst case it might finally seize up and lock the front or rear shaft and snap it. The now broken driveshaft falls and catches the moving road and bounces your jeep off the ground, maybe busting your rear pinion on the axle or maybe just some horrible sounding crunching bending sounds from the front end. Just hope you are nowhere near a cliff or oncoming traffic, you know nuns and such. Not sure, but could guess it could lock up in a way at speed and take the transmission out? Or it goes much better than that for a while and it just slings and splashes the oil out all over until it's at the level of fluid gets to where it's at now and eventually burns up some stuff cause it's not being run near what the operation fluid level is. The outlook isn't good. I wouldn't drive it anywhere there are other people or peoples stuff.
J03_TJ is offline
post #18 of 52 Old 09-03-2014, 08:55 PM
Jerry Bransford
Administrator
The problem with trying to add ATF and driving it afterward is that hole didn't happen by itself. Something inside the transfer case came loose or broke, likely the chain, and broke that hole from the inside. You're just asking for a catastrophic failure if the OP tries to drive with it as is.
post #19 of 52 Old 09-03-2014, 09:39 PM Thread Starter
seankeenan
Thank you for clarifying. The jeep is now at a shop for a diagnosis. I've found a good looking case on ebay ( http://www.ebay.com/itm/Jeep-Wrangle...c2dc6d&vxp=mtr ), but I'm hoping the fix just requires something along these lines: https://www.google.com/shopping/prod...d=0CMwBEKYrMAY with some fresh fluid.
I apologize to everyone I annoyed in this thread by not having a firm understanding of this part of the drive train. Actually, isn't that why I have an account on here?
Dang, I finally have a TJ.
seankeenan is offline
post #20 of 52 Old 09-03-2014, 09:45 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by seankeenan View Post
-The only advice I received was, "I wouldn't drive it."
-My question was, why not? I wanted definitive evidence suggesting the problem could escalate. Your post was rude and uninformative. Thanks for that.
-Also... You're*
Thanks for being blunt. I'm not familiar with the anatomy inside the t case, so I wasn't sure if the rear drive shaft simply moved through it. I will take it in tomorrow.
I appreciate the explanation. That's just what I was looking for and hoping not to find. I'm glad you two were exponentially more informative than brokenyoujoint.
If you drive it, that is the equivalent of having a piston seize up in the cylinder bore, dropping the oil pan and removing the connecting rod so you could keep driving it. It may work for awhile, but it won't work forever.
That is about a 300 dollar repair at the most if you can do the work yourself. Given your horrid lack of maintenance though, I suspect that you will find more issues that will really slow down the t-case swap.
Find a used compatible t-case, swap it in and turn the radio down. That didn't get that way quietly, it made some noise to let you know that there was bad stuff going on.
If you were mechanically inclined, you could pop off the front driveshaft, pull the back have of the case and remove the chain and front output shaft assembly. After that you could pack some grease in the planetary gear and that would buy you some time until you find a case, but again, that only temporary and it will eventually fail.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #21 of 52 Old 09-03-2014, 09:46 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I have a very firm understanding of how it works so no it wouldn't be why I have an account. We all have them for different reasons, not all are the same.
I am Savvy
mrblaine is offline
post #22 of 52 Old 09-03-2014, 09:47 PM
hndswthtshdws
Rear driveshaft when in 2hi just passes power straight through, doesn't use any gears or chains.
If you pull the front shaft the chain won't spin when driving. Might have to wire up the output shaft so it doesnt spin from internal/oil drag.
Probably could have covered up the hole, put fluid in it, and driven around for quite awhile. It'd be a time bomb though.
If you filter out everything that has bad spelling and grammar, you can believe 95% of what you read on the Internet.
hndswthtshdws is offline
post #23 of 52 Old 09-03-2014, 09:53 PM
1ofakind
My god that is quite the hole! I have a spare 231 but I'm in Canada
1ofakind is offline
post #24 of 52 Old 09-04-2014, 01:53 AM
wushaw
Rockin jeep
wushaw's Avatar
Nice, someone actually run their case till it wore a hole in the side...good job
wushaw is offline
post #25 of 52 Old 09-04-2014, 03:59 AM
bdserv
The output shaft goes through bearings. Bearings need lubrication. Lubrication comes from TC fluid.
bdserv is offline
post #26 of 52 Old 09-04-2014, 04:25 AM
festerw
festerw's Avatar
Not sure why you're set on rebuilding it, 231's can be had for around $200. Throw a used one in and go.
Hers - 2011 Dodge Durango Crew
Mine - 2004 Toyota Tundra DC SR5
festerw is offline
post #27 of 52 Old 09-04-2014, 07:33 AM
BM3
BM3's Avatar
maybe it's just me, but the bigger hole on the top & sides looked almost to perfect to be ripped. The bottom edge looks ripped off, but the sides look & top don't. Is that spot a known weak spot in the TC case??
BM3 is offline
post #28 of 52 Old 09-04-2014, 07:43 AM
J03_TJ
J03_TJ's Avatar
I was thinking the same kind of thing, and it's still drivable (well sort of I suppose). Sure does show how robust the 231 is. It will make me worry a little less the next time my rear output starts leaking a little fluid.
J03_TJ is offline
post #29 of 52 Old 09-04-2014, 07:59 AM
jjvw
jjvw's Avatar
From what I am gathering, the worn out chain has been knocking around the inside of the case. I would suspect that there are ribs and gussets lining the edges of the breaks.
Sean, this is among the reasons why you will be replacing rather than repairing your transfer case. There is more than just a hole in the case. Something far more fundamental caused it, like lack of maintenance.
How long have you had the Jeep? How many miles are on it?
2003 Rubicon
jjvw is offline
post #30 of 52 Old 09-04-2014, 08:04 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I'm trying to figure out how the output shaft bearing hasn't died yet. Unless it semi died and then wore out enough to not seize up.
I am Savvy
mrblaine is offline
