switch panels - JeepForum.com
post #1 of 136 Old 11-30-2009, 07:51 PM Thread Starter
BEAST
BEAST's Avatar
switch panels
Ok im gona try to start a new thread. Switch panels in your tj if you could post how you have your light switches ect... post it here. might help people like me who is just starting with there jeep
BEAST is offline
post #2 of 136 Old 11-30-2009, 08:29 PM
Knuckelhead
R.I.P. Knuckelhead
Knuckelhead's Avatar
Gone but not forgotten.
Knuckelhead is offline
post #3 of 136 Old 11-30-2009, 09:25 PM
2003X
2003X's Avatar
2014 JK Wrangler
I used black squares from Jeep and got blue toggle switches.
My Build
2003X is offline
post #4 of 136 Old 11-30-2009, 09:39 PM
B_faster
I am new to the Jeep world, but why are you monitoring your A/F? Is there custom tuning available for the Jeep?
Sorry for the hijack.
B_faster is offline
post #5 of 136 Old 11-30-2009, 10:16 PM
SpaceWrangler
Gnarly Adventurer
SpaceWrangler's Avatar
Location: Where the Girls Dance Different With Familiar Grace
Help a brother out with the black squares' part number?
"It always seems impossible until it is done." -Nelson Mandela
SpaceWrangler is offline
post #6 of 136 Old 11-30-2009, 10:20 PM
Sobie
Bolt-on Maniac
Sobie's Avatar
You could always drill out the blanks
USAF
Sobie is offline
post #7 of 136 Old 11-30-2009, 11:26 PM
SpaceWrangler
Gnarly Adventurer
Yeah, but I'm a couple short of a full panel. Just looking for a couple replacements is all.
I guess they ought to be in the dealer's parts fiche, if nobody know the numbers.
post #8 of 136 Old 11-30-2009, 11:29 PM
MisterO
MisterO's Avatar
the blanks are the black squares he speaks of..
MisterO is offline
post #9 of 136 Old 11-30-2009, 11:45 PM
RaggedOleMan
RaggedOleMan's Avatar
10 switches total. The 5-gang switch panel is flanked by the two rockers. The rocker to the left is a "master" switch that powers up the other 6 switches to the right of it.
I removed the factory portion of the console and fabricated a switch panel out of 1/4" smoked Plexiglass. Operates: Fog lights, under carriage lights, rear (2x) back up lights in Rampage bumper. the remaining three are intended for selectable lockers & OBA. The switch near the steering column is a winch switch, and the little switch below the column cancels the door activated dome light & dinging sound...I retained/re-installed the ACC & ciggy butt lighter very near the factory location. The CB bracket can be seen below the switch bank.
The 5 toggle switches have red LED when in the "off" position. When activated the light is "green". Total cost less than $75.00.
RaggedOleMan is offline
post #10 of 136 Old 12-01-2009, 04:08 AM
masterwacker
masterwacker's Avatar
Here is my the switch panel, cb holder I built. No switches in the picture but the switch port holds 5 contura switches now. Clicky to make biggy.
masterwacker is offline
post #11 of 136 Old 12-01-2009, 05:36 AM
tjthorson
tjthorson's Avatar
Great thread idea - I thought I would go out and shoot a cell pic for you all - because I gave it lots of thought when I came up with mine. My factory switches were all filled up, so I needed to do something else. I originally wanted to do a SPOD, but the prices was just too steep for me. I bought the blank double gauge pod ($39) and carefully used a dremel with cutoff wheels to cut out my switches. The extra space on the right I originally wanted to use for a gauge for my OBA - but since I dont have a tank hooked up to it or anything, I decided not to. Im not sure what to do with the right side of the pod yet... Another thing you might notice is the non original radio. That one is out of a Grand Cherokee - I wanted the cassette player so I would have an easy way to "aux in" the satellite (staying with a stock radio makes it less theft-friendly). It plugged right into the factory wiring and works great.
The switches currently in use are:
2 blue switches, front and rear lockers.
middle green switch, unused.
right green switch, OBA compressor.
Bottom left small square red momentary switch - switches rooftop amber light bar strobe pattern.
Bottom Left amber switch, rooftop intercepter amber light bar
first (most left) red switch, hood mounted halogen 6 light bar
middle red switch - currently unused, but for roof bar mounted halogens (coming soon)
right side red switch - currently unused, but for rear mounted halogens (coming soon)
Todd Thorson
2013 JKU Gecko Green
tjthorson is offline
post #12 of 136 Old 12-01-2009, 06:55 AM
robncar
robncar's Avatar
This is the sPod:
4x4 SPOD
https://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #13 of 136 Old 12-01-2009, 07:25 AM
Brew461
I am here to tell you if you need an aux switch call James at OTRATTW. Just go to the website and look at the panel on the main page. That is the one i got. I got a 'factory second'. It took me and another guy 10 min to find a ''flaw''. James is knowledgeable and knows what customer service is. He ships on time at cost. I needed an on/on switch 2 weeks after installing the panel. he had one drop shipped to me in two days and shipped me the rocker at NO COST. Hands down thd best out there.
Mine: 03 TJ
Hers: 01 XJ
Brew461 is offline
post #14 of 136 Old 12-01-2009, 08:43 AM
nriver
2011 JK Wrangler
Why do I post here?
nriver is offline
post #15 of 136 Old 12-01-2009, 06:26 PM
2003X
2003X's Avatar
2014 JK Wrangler
I took one and went to Jeep and the guy looked up the part #. Its on the sqaure on the back.
My Build
2003X is offline
Custom switch panels Bridgeman YJ Wrangler Technical Forum 4 01-05-2010 07:10 PM
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 10:21 PM
Extra Switch Panels? jeepgunner12 TJ Wrangler Technical Forum 11 11-20-2009 12:47 PM
Rocker Switch Panels Cchandler TJ Wrangler Technical Forum 38 10-23-2009 07:36 PM
Your Yj Switch Panels... Bradish YJ Wrangler Technical Forum 2 10-11-2006 08:29 PM
