Switch blanks - gettin 'em out - JeepForum.com
post #1 of 8 Old 05-17-2006, 01:38 PM Thread Starter
nman642000
Guest
What's the best way y'all have found to get the switch blanks out of the center console on your TJs? I ordered some KC Daylighters for my windshield brackets and want to put the switch there next to the stock fog lamp switch.
Any ideas?
nman642000 is offline
post #2 of 8 Old 05-17-2006, 01:54 PM
TJgreg
TJgreg's Avatar
once you get the console surround off, there are 4 screws to take out. Disconnect the two cigarette lighter outlest and any other swithes There are two tabs you need to depress, on on top, one on bottom of the blanks. After pressing them down, the blank should pop right out the back. If not, use some small pliers to give em a little tug. This is how it worked on my 05, probably similar if not the same as yours
Semper Fi
TJgreg is offline
post #3 of 8 Old 05-17-2006, 02:05 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Originally Posted by TJgreg
once you get the console surround off, there are 4 screws to take out. Disconnect the two cigarette lighter outlest and any other swithes There are two tabs you need to depress, on on top, one on bottom of the blanks. After pressing them down, the blank should pop right out the pach. If not, use some small pliers to give em a little tug. This is hw it worked on my 05, probably similar if not the same as yours
it same on my 99 as well
RnEmOvr is offline
post #4 of 8 Old 05-17-2006, 02:16 PM
JESSETHELJ
JESSETHELJ's Avatar
Just remember they push out the back dont try to push it out the front. I broke the cluster and had to pay 32 bucks at the dealer.
JESSETHELJ is offline
post #5 of 8 Old 05-17-2006, 04:10 PM Thread Starter
nman642000
Guest
Thanks! I'll let ya know how it goes. any hints on taking the console surround off without breaking any of the plastic or seriously warping it?
post #6 of 8 Old 05-17-2006, 04:20 PM
TJgreg
TJgreg's Avatar
there are two screws up on top (under the trim panel on top of that dash that goes the full length of the dash) Take a flat head screwdriver and gently pry that piece upwards, theres a few clips holding it in. Take the two screws out and take the flathead and pry out the center piece just like you did with the top. I believe there might only be 2 clips holding that one in, though maybe 4. Just be gentle with it and you wont have any problems.
Semper Fi
TJgreg is offline
post #7 of 8 Old 05-17-2006, 06:42 PM
forcephil
Guest
Once you remove the two screws in front of the catch-all tray, you should be able to just pull GENTLY, and the whole thing will come right off.... just be patient...
forcephil is offline
post #8 of 8 Old 05-17-2006, 08:03 PM
Achped
2017 JK Wrangler
Don't forget about the screw behind the ash tray.
Achped is offline
Switch blanks.... in the center of the dash. denalijb TJ Wrangler Technical Forum 11 06-28-2011 03:51 PM
Mounting switches in stock switch blanks? drummerdude1234 TJ Wrangler Technical Forum 26 08-25-2009 10:28 AM
Switch blanks? Silver04TJ Wrangler General Discussion 1 07-28-2008 12:57 PM
Buliding a shopping list..please fill in the blanks for me! IWantMyMTZ YJ Wrangler Technical Forum 2 04-24-2008 10:48 AM
Switch Blanks Flyusaf2002 TJ Wrangler Technical Forum 11 02-16-2005 10:22 AM
