Switch blanks.... in the center of the dash. - JeepForum.com
post #1 of 12 Old 08-11-2004, 01:45 PM Thread Starter
denalijb
Anyone know how to remove the blank pieces of plastic out of the switch bay right next to the lighter? I have two that are used and one free. I want to use the plastic piece for a mount for a switch I'm putting in. Thanks in advance.
denalijb is offline
post #2 of 12 Old 08-11-2004, 01:51 PM
penguinland
penguinland's Avatar
Remove the front panel that surrounds the radio etc. it's only 4 screws. Take a small flat screwdriver and insert it between the blank and the panel. It should release from the tab and slide right out. If you are going to mount a switch in the blank you will want to use a dremel to drill the hole as a drill bit will shatter the plastic. I broke 2 when I was putting my foglights switch in
2004 WJ 4.0
2" BDS springs + 3/4" spacers up front , Goodyear Duratrac 245/75R16, Yaesu FT-7900R
penguinland is offline
post #3 of 12 Old 08-11-2004, 02:22 PM
James04TJ
Guest
The blanks are a PIA to get out. I just broke them out. I forget what the correct size switch is for the dash but they have exact fit switches at Western Auto and they even have a small tab on them to show what the switch is for.
James04TJ is offline
post #4 of 12 Old 08-11-2004, 02:26 PM
yurmom22
Guest
Follow the instructions given above...the center dash piece is not difficult to remove at all...and then you can just push out the 'blank' pieces once the center bezel is out. I did this last weekend to install a switch for my lights...
HTH
yurmom22 is offline
post #5 of 12 Old 08-11-2004, 03:06 PM Thread Starter
denalijb
Sweet thanks all, I'm getting sick of my garage door opener and I'm going to hide it in the dash somewhere.
denalijb is offline
post #6 of 12 Old 06-27-2011, 01:58 PM
adz4play
dunno if im going blind but i cant see any tiny screws on my dash centre panel. Ive got a daystar switch to fit for my spots...
adz4play is offline
post #7 of 12 Old 06-27-2011, 02:02 PM
ajf1994
ajf1994's Avatar
On my '04, the procedure is to remove the horizontal piece across the top of the dash. Then take out the two screws on top (phillips). Then with some gentle prying, the whole center section will pop out. Then, the bottom part that holds the switches has four screws around the perimeter that need to be removed. Then you are good to go!
-SupportOurTroops-
High School Jeepers #361
Parrothead Jeep Club #46
37,xxx Miles
Originally Posted by XJ-Tim View Post
my welds look like popcorn with sprinkles.
Originally Posted by Benjamin Franklin
Beer is proof that God loves us and wants us to be happy.
ajf1994 is offline
post #8 of 12 Old 06-27-2011, 02:05 PM
adz4play
cheers dude, ill have a play tomorrow, its getting dark now..
adz4play is offline
post #9 of 12 Old 06-28-2011, 02:52 AM
wesboy
The early models have another screw behind the ash tray securing the centre section.
wesboy is offline
post #10 of 12 Old 06-28-2011, 06:37 AM
UnsanePyro
I did that a couple summers ago in mine. Pulled the opener apart, wired in a momentary contact switch to mounted it behind the dash with the switch in one of the blanks. Worked out great, and it was one less thing to leave loose in the Jeep with the top being down all the time so I was happy.
UnsanePyro is offline
post #11 of 12 Old 06-28-2011, 02:31 PM
lupinsea
lupinsea's Avatar
To get to the top screws you need to (gently) pry up the very top piece of dash that runs parallel and adjacent to the base of the windshield. There are five spring-clips that hold it in place spaced approximately evenly along it's length. That will expose the two screw that secure the top of the center dash piece.
Next, remove the ash tray and there should be a third screw behind that. Once all three screws are out gently pry off the whole center plastic piece.
The switch panel is dangling down below
the dash next to the transmission shifter.
This will expose the four screws holding the switch panel in place. Remove the screws and the switch panel comes out so you have access to the back of it.
Again, as mentioned, gently pry up to release the blanks. I just did this last night when I installed a switch for my locker. I found an aftermarket OEM-like switch that is design to snap right into one of the switch blanks. It came with a nice plug and some wire leads. Here are two sources for it:
TJ Rocker Switch 1
TJ Rocker Switch 2
- Jay
lupinsea is offline
post #12 of 12 Old 06-28-2011, 03:51 PM
adz4play
tip top read dude..cheers
adz4play is offline
Help removing center dash for aux switch dogbluedrummer TJ Wrangler Technical Forum 6 01-10-2011 11:11 AM
Mounting switches in stock switch blanks? drummerdude1234 TJ Wrangler Technical Forum 26 08-25-2009 10:28 AM
Switch blanks? Silver04TJ Wrangler General Discussion 1 07-28-2008 12:57 PM
Switch blanks - gettin 'em out nman642000 TJ Wrangler Technical Forum 7 05-17-2006 08:03 PM
Switch Blanks Flyusaf2002 TJ Wrangler Technical Forum 11 02-16-2005 10:22 AM
