is it the switch??? - JeepForum.com
post #1 of 11 Old 11-04-2009, 09:48 AM Thread Starter
gratefuljeep
is it the switch???
so i went to the dealer today to pick up a blower motor switch because my blower was only working on speed one. the parts guy said its probally my resistor and not the switch. so i got the resistor instead and put it in. pulling out my old one i saw it was all rusted and cruddy looking so i figured that was the problem. the wires on the plug all looked ok to me. tested it out and still no other speeds but one and now the air only comes out of the defroster. what should i do or check??
gratefuljeep is offline
post #2 of 11 Old 11-04-2009, 09:51 AM
Fett
Mechanically Declined
Fett's Avatar
Try replacing the switch. I had the same problem when I first got my jeep. Pulled out the switch/knob assembly and cleaned all the contacts. Works fine ever since, but it was a PITA to reassemble. Next time I'll just buy a new switch.
99 TJ Sport I64L Manual 31x10.5 RE 3.5" Super Flex 1"BL 3.73 gears w/LockRite in front. Warrior Safari Rack.
"When you honestly believe you can compensate for lack of skill by doubling your efforts, there's no end to what you can't do".
|_
|T|
Fett is offline
post #3 of 11 Old 11-04-2009, 09:52 AM
IOUnlimited
Air coming out of defroster is often a vacuum leak from the manifold. You can order an entire switch panel from chryslerpartsdirect.com cheaper than your local dealer.
My blower switch melted entirely making it necessary to replace the set. There are several good write ups on here, search "blower motor" or "blower switch".
IOUnlimited is offline
post #4 of 11 Old 11-04-2009, 10:23 AM
dcope17
dcope17's Avatar
Switch is easy to check with an ohm meter. Just a 4 position switch meaning 1 line in and 4 out.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #5 of 11 Old 11-10-2009, 09:32 AM Thread Starter
gratefuljeep
ended up being the switch. the parts guy was cool and gave me wholesale cost on the new switch because i listened to him and had to spend 47$ on the resistor the first time which i didnt need, but probally would have down the road.
post #6 of 11 Old 11-10-2009, 10:30 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
I'm glad he gave you a deal since he gave you the wrong info to begin with. I'm sure he probably didn't know better, but for future reference a faulty resistor will not affect the highest speed setting.
I'll be Savvy someday!
neZZr is offline
post #7 of 11 Old 11-10-2009, 11:27 PM
Brew461
where on the manifold would you expect the leak?
Mine: 03 TJ
Hers: 01 XJ
Brew461 is offline
post #8 of 11 Old 11-11-2009, 05:14 PM Thread Starter
gratefuljeep
Yeah I knew that it would work only on hi going in there if it was the resistor. He told me in his '03 he replaced 3 resistors already and really thought that was the problem. But its fixed and hopefully i wont have to go to the dealer for dealer parts any time soon.
post #9 of 11 Old 11-11-2009, 06:42 PM
Neil F.
47 on the resistor!!!!!!!!!?????????? The resistor should be around 20. My local dealer charged me 24 last week. I know pwople have pais less.
Neil F. is offline
post #10 of 11 Old 11-11-2009, 06:46 PM
1AAuto.com
1A Auto Parts
1AAuto.com's Avatar
Sounds like you made out ok
1AAuto.com is offline
post #11 of 11 Old 11-11-2009, 07:09 PM
greenlay
Guest
I also had the blower stop working in my 98 TJ w/AC. I purchased a 05011214aa switch from the dealer (who wanted to sell me the entire unit). It doesn't quite fit. The holes are wrong and the speeds are medium high low and very high as you click through the speeds. The post is too thin for the knob as well. It is working though. Does anyone have a different part number for the switch I need?
greenlay is offline
2003 TJ - Moving fog light switch from MFS to toggle switch TJeep_1999 TJ Wrangler Technical Forum 10 08-05-2015 05:07 PM
aftermarket horn wired to switch, would like stock to work on switch as well hilton00 TJ Wrangler Technical Forum 14 01-02-2010 03:11 PM
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 10:21 PM
Having problems with lights. Does the dimmer switch run through the headlight switch? spshultz YJ Wrangler Technical Forum 2 10-25-2009 07:43 AM
Replacing fog light stalk switch with dash mounted switch? Imped TJ Wrangler Technical Forum 7 08-31-2008 01:58 PM
