swapping a 2002 TJ onto a 2003 frame - JeepForum.com
post #1 of 5 Old 11-24-2021, 08:30 AM Thread Starter
will0822
will0822's Avatar
my beloved 2002 jeep tj that i have had for 11 years had frame rot bad, so living in New England finding a new rust free frame was hard. luckily for me i found a great deal on a 2003 frame with the steering box mount fixed to run the old style box, frame notched in the rear with coil over towers in it, and a Rubicon Express tummy tuck skid plate and long arm control arms on it. I blasted the new frame and painted it black, bought new metal cloak dual rate coils and swapped my old axles over to it, upgraded the track bars, installed new brake lines, and then stabbed the motor and trans into the new frame (which was not easy by myself). and then my error was discovered... the transmission mount is about an inch from the holes in the skid plate. does anyone know how to remedy this without having to swap to an 03-06 transmission?
will0822 is offline
post #2 of 5 Old 11-25-2021, 06:46 PM
Jeepsr4me
If your local parts store has the trans mount for the newer frame look at it to see if the studs are in the right spot. I remember running into this swapping 05 frame from a 2001..
OR just drill holes in the skid plate. I have a welder and could just cut the slotted area out and realign it to the right spot and weld back up
Jeepsr4me is offline
post #3 of 5 Old 11-30-2021, 01:40 PM Thread Starter
will0822
will0822's Avatar
Update: it turns out the real issue is my transfer case is hitting the skid plate keeping the bolts from going into the holes?
will0822 is offline
post #4 of 5 Old 11-30-2021, 04:32 PM
Jeepsr4me
Look and see if your engine mounts is good. If its allowing the engine to tilt it will also tilt the t case.
post #5 of 5 Old 12-01-2021, 09:45 AM Thread Starter
will0822
will0822's Avatar
I have tried it with the factory mounts and with 1" lift mounts on the engine. the transfer case hits either way. its seems like i need a spacer of some sort to ever make this happen, or to some how clock the T-case on the transmission so its in more of a 9 O'clock position rather than a 7-8 O'clock position (though i don't see how that could be achievable)
will0822 is offline
frame swap , jeep tj , long arm kit , metal cloak , rubicon express
