Super 35 or Built Axle - JeepForum.com
 8Likes
post #1 of 39 Old 05-08-2020, 01:00 PM Thread Starter
Tymeks
Hello,
1st time post here. Finally pulled the trigger on a base ‘06 TJ. It needs some love. I’m a shade tree mechanic without issue but my question is this. The rig needs to be regeared along with a bunch of other stuff. I figured since the fluid needs changing, and the seals need changing, mine as well do it right.
This will not be a rock crawler, it will be a light trail at most with the family type of rig.
So the question is this.
Doing it right, do I swap in a Super 35 or a built axle from G2 or Currie or something like that.
The question is more geared towards the labor part of it. I don’t feel like I’ll be able to set the pre-load or complete the regearing myself so I’ll want that done by a shop. But I would have no issue dropping an axle and replacing it with a built one already.
So since, I’ll have to pay for labor on the Super 35 but not on the built axle, am I better off just swapping in the axle?
It currently only has a 1 inch body lift on it, but I do plan on lifting it more to put 33’s or 35’s on it. But for sure, just light camping trails is all it’ll probably see.
Lastly, since this is not going to be a rock crawler of any kind, what’s the most effective diff for me?
Tymeks is offline
post #2 of 39 Old 05-08-2020, 01:33 PM
sycboi
Trail use and light off-road I would think a Super 35 setup should last you the life of the Jeep. 33s won’t be a problem at all. An aftermarket differential will end up costing way more than setting up what you have...
SuperBeast, enforcer for the Mopar Mafia ̿ '̿'̿\̵͇̿̿\з=(ē̪●)=ε/̵͇̿̿/'̿'̿ ̿
sycboi is offline
post #3 of 39 Old 05-08-2020, 03:03 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
A Super 35 would work for you. Cost will end up being around $2k including the regear and install.
You could try to find a used Dana 44, but it's not easy and they're not cheap. Here is one for $1,200:
https://daveysjeeps.com/parts/produc...ar-axle-3.73/?
Personally I wouldn't pay $1,200 for a stock TJ D44. You'll spend another $800-1,000 regearing it. That puts you at S35 cost, but without a locker.
If you could find a Rubi axle with a working locker for say around $1,200, that wouldn't be a bad deal.
Wheelin98TJ is offline
post #4 of 39 Old 05-08-2020, 04:52 PM
fxrsliberty
1935 CJ2A
A bunch of people are about to tell you about the 8.8 it's a waste of your time and you don't sound like you want to weld, re-gear or spend 100$ extra. The Super 35 will do everything you want and 35s aren't out of the question. If you can, drop the axle off at shop just for the re-gear and carrier upgrade. A lot of them charge less if your not taking up a lift. I tried to upload my Jeep pics as evidence that I've done this but they are v to big...
Sent from my Pixel using Tapatalk
fxrsliberty is offline
post #5 of 39 Old 05-08-2020, 05:06 PM Thread Starter
Tymeks
Thatís actually a fantastic idea to keep the costs down. Thank you for that. Not really sure why i didnít think of that before. Thatís what Iíll do, Iíll drop the axle myself and pay a shop to regear it for me. Teamwork makes the dreamwork!! Thanks again.
fxrsliberty likes this.
Tymeks is offline
post #6 of 39 Old 05-09-2020, 07:58 AM
rikkards
rikkards's Avatar
X2, and I can say that since I have an 8.8. There is a good sense of security in the fact that I don't need to worry about breaking anything with what I have but when I did it the S35 wasn't available and if I was going to do it now I would have gone that route
Machete don't tweet
- Machete
rikkards is offline
post #7 of 39 Old 05-09-2020, 10:39 AM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Damn, your Jeep is old! I think the S35 was available in 01'? The HP 30 and 8.25 on my XJ seem to hold up very well with upgraded shafts. I could have got a lot of free 8.8 axles years ago. My buddy loved his Ford ExPloders and the transmissions went bad way before the rear axles ever had a problem.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
GOT IT BACK on 6/17. 03' Rubicon/Zone 4.25" combo lift with 4" lift coils up front/Zone hydro shocks/5.13 gears/35" Mickey Thompson MTZ P3 tires/Black Magic brakes. Jeep #17 & 19.
SOLD 99' XJ /4.0L-AW4/ 5.5" lift / 33" DC tires.
TheBoogieman is offline
post #8 of 39 Old 05-09-2020, 12:04 PM Thread Starter
Tymeks
My plan at this point is to drop the axles and drop them off at a shop to be regeared.
With that being said, what’s a fair price I should expect to pay a shop for labor to install the new gears and E-Locker?
Tymeks is offline
post #9 of 39 Old 05-09-2020, 12:53 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
With that being said, whatís a fair price I should expect to pay a shop for labor to install the new gears and E-Locker?
Are you planning to do the super 35?
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is online now
post #10 of 39 Old 05-09-2020, 01:34 PM
Stumptown
Call your shop and ask them if it makes a difference to them if the axles are out or not. I know when I regeared, it was the same price. Now I wished I would have ponied up and payed for the lockers at the same time...
bobjp likes this.
Stumptown is offline
post #11 of 39 Old 05-09-2020, 01:43 PM
bobjp
I would not pull axles to have them regeared unless I had gotten a quote stating that it is significantly cheaper over leaving them in the Jeep. It is not easy to remove and reinstall them. It's not rocket science, but it is quite a bit of work. It's worse if you've never done it or if none of the bolts have been touched since the Jeep was built.
Maybe I'm wrong, but it doesn't seem like you have done much reading and considered all of your options.
Camping trails don't require much more than stock. 31's and an auto locker up front go a long way. Locking the D35 without upgrading axle shafts is generally considered unwise. There are other things to be considered when going to 35's.
I would guess $2000 for one Eaton E-locker and both gear sets installed.
97 TJ sport.
bobjp is online now
post #12 of 39 Old 05-09-2020, 01:56 PM Thread Starter
Tymeks
Iíve been doing a bunch of reading but for sure, Iím new to the Jeep world. Iíve built race cars a plenty in the past but am quickly learning that it doesnít translate much to the Jeep world. :/ But thatís ok, I enjoy wrenching and building.
My plan is to do a super35 with upgraded axles and a locker in the rear, regearing both the front and the back at the same time. Current gearing is the stock 3.07ís. So I was going to fit in some 4.56ís. Does that sound about right? If matching the gearing upfront, do I need to put a locker in there as well?
That seems to be the most cost effective way of building it right without wanting to build a rock crawler.
Tymeks is offline
post #13 of 39 Old 05-09-2020, 02:07 PM
bobjp
None of that sounds bad depending on what else you plan to do. Tire size and transmission type drive many other changes including gear choice. It doesn't sound like you've nailed down the tire size and maybe not considered the other things required for that particular size including the gearing, lift, steering, and brakes.
What transmission do you have? There are a lot of documented opinions out there about the appropriate gear for a particular tire size and transmission.
Choose a tire size and lift height, and then go from there.
No, a front locker is not required to match the rear. I would install one, but I also do more than camping trails.
97 TJ sport.
bobjp is online now
post #14 of 39 Old 05-09-2020, 02:13 PM Thread Starter
Tymeks
I have the 6 speed trans. So I figured with the 6th gear overdrive I wouldnít need anything smaller than 4.56ís. Itís really the wifeís Jeep so for sure, highway gearing is still important. So I figured a compromise was 4.56ís. Is that about right?
I plan on doing a 3 inch lift ( I started a separate thread on that ). As well, I plan on 33ís. I was thinking 35ís because......well, itís cooler to say I have 35ís, lol. But in reality 33ís will look good and get the job done.....light camping trails.
Tymeks is offline
post #15 of 39 Old 05-09-2020, 02:24 PM
Stumptown
Sorry, didn't notice, but stick or auto? If auto, go as deep as you can. I have 5.13's and wish I was lower. But that is a new front axle, and I don't want to do that.
You think you are building a soft camping vehicle. You are not. You will buy incremental upgrades as you thing you need them, and spend a ton of money in the process. Just rip the band-aid and go big. Lift, gears, lockers maybe if you are just camping. If you aren't rock crawling and mudding, that front axle is just fine.
And as a mild family rig? Stock is perfectly fine. Define your real usage, and build to that. Not a rock crawler, fine. Not a mudder, fine. Precious cargo inside? My first mod would be a cage to keep them safe.
I came from the racing world also. The jeep stuff is surprising cheap in comparison. Just having a set of tires that I can take off road more than once is awesome!
