Stupid question: Best way to paint metal parts like rockers or skid plates?? - JeepForum.com
post #1 of 11 Old 10-18-2012, 06:57 AM Thread Starter
dan188
This may sound like a really dumb question, but what have you guys found to be the best way to paint metal parts that get abused, such as tube fenders, rocker guards, or skid plates? I am asking this question because I recently installed a steel Rokmen tummy tuck and last night I scratched the paint when a wrench slipped as I was working on another part of the Jeep. I have also scratched the crap out of my rocker guards that I painted about a year ago, and most of those scratches aren't even from trail abuse . My first thought was that maybe I am just expecting too much from "regular spray paint" or maybe I am not putting enough coats on? For my rocker guards and skid plate I used metal etching primer (2 coats) and then used flat black Krylon enamel (also 2 coats).
Any recommendations on better paint products (aside from powder coating) or any paint application tips? I was also wondering if maybe I should use a clear coat on top of the paint to give some additional protection?
dan188 is offline
post #2 of 11 Old 10-18-2012, 07:05 AM
Imped
Imped's Avatar
Waste as little time and money as possible on parts that will just get scratched up....the frame, the skids, rocker guards, etc. If they're scratched, touch them up and move on. People spend way too much time worrying about the quality of their paint jobs on parts that are there to protect.....8 coats of primer, 10 coats of paint and 4 coats of clearcoat just to go swap with a rock. The main focus should just be keeping them painted and keeping your rig clean and rust free. Rust looks much worse and is more harmful than a quick rattle can paint job. My entire Jeep is rattle can.....does it look perfect? Hell no. Do I really care? Hell no. Is it rust free? Hell yes. Plus, I never worry about my paint and can quickly and easily touch it up.
I use Krylon Dual. Loving it.
OlllllllO
IndyORV
Imped is offline
post #3 of 11 Old 10-18-2012, 07:11 AM
GMBNT42
Get some cheap primer, and cheap frame paint, go to town. Its goinna get gouged and scratched up. So touch up as needed afterwards. Simple as that.
GMBNT42 is offline
post #4 of 11 Old 10-18-2012, 07:46 AM Thread Starter
dan188
ok that sounds good. I agree that rust-free metal and a rattle can paint job is better than spending hours on perfect paint that is just going to get abused, but I want to make sure that the paint job isn't so thin that a stone from the tires will take the paint off. The idea of a "tougher paint job" is on my mind because the winter salty months are almost here, and I want to prevent as much rust from forming as possible. I expect to scratch everything when I am on the trails and I always go back and touch things up, but when I dropped my wrench and scratched the paint on my skid my first thought was "Damn it, if that scratched the paint then how will this paint hold up over the winter with the stone chips and salt all over it?". I will check out the Krylon Dual and some good frame paint.
dan188 is offline
post #5 of 11 Old 10-18-2012, 07:52 AM
hustler905
hustler905's Avatar
I get Tremclad tractor paint in a can (not aerosol) and apply it with a foam roller. Personally, I find it coats a lot better than the spray on stuff and tends to be more durable. No primer, no top coat, just two thick coats of that stuff works for me.
hustler905 is offline
post #6 of 11 Old 10-18-2012, 09:09 AM
TheRealKTrain
JK Wrangler
Originally Posted by dan188 View Post
but when I dropped my wrench and scratched the paint on my skid my first thought was "Damn it, if that scratched the paint then how will this paint hold up over the winter with the stone chips and salt all over it.
That's the point of spray paint. It's literally a two second touch up. There is no way to get an easier touch up than cracking the lid, aiming, shooting, putting the lid back on.
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #7 of 11 Old 10-18-2012, 09:17 AM
BYuen
BYuen's Avatar
I use Rustoleum rattle can enamel. Holds up a little better than the regular stuff.
2001 White TJ Sport
2013 Black JKU Rubicon 10A
BYuen is offline
post #8 of 11 Old 10-18-2012, 11:43 AM
srlbotanical
srlbotanical's Avatar
Same here. Rattle can gloss black.
Gloss seems to hold up and clean up better.
I like a good oil base rustolium in a can for things that are under the jeep. I paint it on with a brush or roller, good and thick.
Two Trackers 4WD Club
Wheeling in West Michigan for over 35 years.
HIGHER POWERED!!
srlbotanical is offline
post #9 of 11 Old 10-18-2012, 11:53 AM
Barcus
Barcus's Avatar
Krylon Dual is the shizz...best rattle can paint ive found.
98 TJ Currie arms-RC 2.5 coils-RC 2.0 shocks-1.25 BL-TF rear track bar-custom bumpstops-mud-scratches-gas.
Barcus is offline
post #10 of 11 Old 10-18-2012, 01:29 PM Thread Starter
dan188
thanks for all the suggestions guys. I will check out the products that you all mentioned. I would like to get a thicker paint job on my skid plate and a few other areas before the winter comes, just to make sure that the salt won't penetrate the paint and turn to rust.
dan188 is offline
post #11 of 11 Old 10-18-2012, 02:29 PM
Cagle
Cagle's Avatar
I have been using a product called Rust bullet from Summit. It creates a hard shell. You can apply it with brush,roller or cup gun. A cheep cup gun at HF is $15 they shoot thick Primer and coatings great.
Cagle is offline
