Stuck throttle speed...but I did search! - JeepForum.com
post #1 of 4 Old 07-14-2010, 01:14 PM Thread Starter
greenrover
greenrover's Avatar
While driving in 1st or 2nd at 2k or 2500 rpm when I let off the gas it just keeps going the same speed....sometimes even speeding up a bit. I have to hit the brakes till around 1500 or so and it seems to give up. If I push the clutch in it'll stay reeving at the same rpm for a couple of seconds before returning to idle.
I'm thinking IAC? Speed sensor? vacuum leak??
I did some searching and didn't come up with anyone who was having the exact symptoms....any ideas would be appreciated.
07 2dr Rubi*2.5" Lift*5.38's*35's*ARB Diff Covers*ARB Bumpers*Milemarker 9.5SX*IPF 900XS Lights
greenrover is offline
post #2 of 4 Old 07-14-2010, 01:17 PM
freeskier93
Do you have cruise control? I'm not sure if the IAC can let enough air in to maintain 2500 RPM, sounds more like the butterfly is sticking or cruise control is acting wonky.
freeskier93 is offline
post #3 of 4 Old 07-14-2010, 01:44 PM Thread Starter
greenrover
greenrover's Avatar
I do have cruise, it's turned off but I'll disconnect it and test.
post #4 of 4 Old 07-14-2010, 01:52 PM
freeskier93
Another suggestion is to take the intake hose off the throttle body, so you can see the butterfly. Then have someone else give it gas and see what happens. Also try opening the butterfly by hand and see if you can feel it sticking.
tj , wrangler , rpm , throttle stuck
5-speed yj is getting stuck in between 1st and 2nd zekeman023 YJ Wrangler Technical Forum 13 03-14-2009 09:23 AM
idle speed and throttle response gfortier YJ Wrangler Technical Forum 3 12-01-2008 02:42 PM
99 Sahara stuck throttle problem DaSouthWon TJ Wrangler Technical Forum 4 03-20-2007 07:57 AM
Throttle Stuck wide open jeepofun TJ Wrangler Technical Forum 10 12-02-2004 08:01 PM
