Stuck in 4wd, doesn't disengage - JeepForum.com
 6Likes
  • 1 Post By 2jhanna
  • 1 Post By 2jhanna
  • 1 Post By 2jhanna
  • 1 Post By mukluk
  • 1 Post By Tarneg
  • 1 Post By 2jhanna
post #1 of 11 Old 11-16-2019, 08:24 PM Thread Starter
Sudcalifornio
Sudcalifornio's Avatar
hello fellow jeepers!!!
Does anybody can show me where should i start checking? and obviously give solutions
Thanks in advance
[B]sudcalifornio[B]instagramand twitter
chapulinon snapchat
Sudcalifornio is offline
post #2 of 11 Old 11-16-2019, 08:46 PM
2jhanna
Crawl under the center portion of your jeep while someone inside shifts the transcase lever. It's not uncommon for the linkage to get loose. From underneath you'll be able to see if so.
Sudcalifornio likes this.
I am multi-talented, I can talk and piss you off at the same time.
jhanna
denton county, tx
2jhanna is offline
post #3 of 11 Old 11-16-2019, 08:50 PM
2jhanna
Here's a video
jhanna
denton county, tx
2jhanna is offline
post #4 of 11 Old 03-27-2020, 11:48 AM Thread Starter
Sudcalifornio
i was driving the jeep then i heard a big breaking sound, then jeep stopped rolling
chapulinon snapchat
post #5 of 11 Old 03-27-2020, 11:55 AM
mukluk
mukluk's Avatar
Have you looked underneath the Jeep to see what broke?
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #6 of 11 Old 03-27-2020, 12:20 PM
2jhanna
Have you still been driving around stuck in 4wd, or did you get that problem fixed ?
jhanna
denton county, tx
2jhanna is offline
post #7 of 11 Old 03-27-2020, 12:34 PM Thread Starter
Sudcalifornio
yes keep driving it with the 4wd stuck until this, it was like couple days
chapulinon snapchat
post #8 of 11 Old 03-27-2020, 01:38 PM
2jhanna
If you continued to drive stuck in 4wd on hard surfaces, you very possibliby have destroyed the t-case.
Making turns on hard surfaces creats a lot of stress and binding on the drive line.
jhanna
denton county, tx
2jhanna is offline
post #9 of 11 Old 03-27-2020, 09:02 PM
mukluk
mukluk's Avatar
Just thinking out loud here, but I would think if something were to let go from excessive driving in 4wd on pavement it would be a driveshaft u-joint or maybe the chain. In any case, it'd seem odd to me to lose both the front and rear drive at the same time. Based on the information it's been driven for a few days in 4wd on pavement, I'm now wondering if maybe the t-case has popped into neutral.
Kind of a shame we have to have this discussion when it only takes ten minutes tops to adjust the shift linkage by yourself.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
post #10 of 11 Old 03-28-2020, 05:31 AM
Tarneg
half thinking but do jeeps have that issue when in 4wd on pavement ?? i have driven my old chevy alot that way and my front and rear diff ratios are actually different in those years and had no issues. But yes being stuck in 4wd with an unknown reason means you should not have driven on it other than to get home and it sounds like what mukluk said and its in neutral now but if it went there with a big bang it may have been forced there and broke stuff along the way. and even a broken chain would only take out the front axle in most cases, if the t case is not in 2 pieces only way to find out is the drop the case and see what the insides are like
Tarneg is offline
post #11 of 11 Old 03-28-2020, 06:31 AM
2jhanna
agreed. My experience is that problems rarely fixed themselves. They either stay the them or get worse.
jhanna
denton county, tx
2jhanna is offline
transfer case
