Stop tie rod flop - will this work? - Page 2 - JeepForum.com
 6Likes
post #16 of 17 Old 09-18-2019, 04:02 PM
jjvw
jjvw's Avatar
Originally Posted by Kiwi_TJ View Post
Originally Posted by jjvw View Post
This is a Currie "hi steer" setup. Can't do much better on stock axles.
Attachment 3859079
Is this just with one of those tapered flip inserts on the tie rod to knuckle side? Was thinking of doing the same thing on my Jeep. Did you have to raise the sway bar mount tab?
Drilled knuckle with an insert. Though I cleaned the insert up with a tapered reamer. The sway bar mounts need to be raised. BMB sells a set. Wheel BS needs to be about 4", but I forget the minimum.
2003 Rubicon
jjvw is offline
post #17 of 17 Old 09-18-2019, 06:38 PM
Pine_Cat
Pine_Cat's Avatar
Originally Posted by vosevichs View Post
I'm sorry the OP bought that kit, but I'll provide another testimonial for the Ruffstuff Cure. After I installed the Cure on my stock inverted-y steering it then felt as precise as IFS.
Subsequently, my tie rod jam nut began refusing to remain thread-locked, so my next project (after work quiets down) is to install a Currie tie rod.
Jerry Bransford likes this.
2017 JK
2016 MK- Murchison springs, ~1" BL, skinny 30s
2011 KK- H&R lift springs, OldManEmu shocks/struts, skinny 31s
2009 Sorento- H&R springs, ToyTec strut spacers, OldManEmu shocks/struts, 31s
2006 TJ budget LCG prerunner- see profile
2006 Trailblazer- EXT lift, Nth LJ 4.5" springs + Monroe rear coilovers, skinny 32s
1998 Durango- SuspMax & Roadmaster lifts, rear Truetrac, skinny 32s
Pine_Cat is offline
