Stop tie rod flop - will this work? - JeepForum.com
 6Likes
post #1 of 17 Old 09-17-2019, 09:03 PM Thread Starter
AWheeler
I have this kit on my TJ. https://www.ballisticfabrication.com...y-tie-rod-ends
I now have the nice tie rod flop going on. Found this product. https://www.synergymfg.com/synergy-j...ust-boots.html
Will this synergy boot fit the HD tie rod ends and will it stop the flop?
AWheeler is offline
post #2 of 17 Old 09-17-2019, 09:25 PM
jjvw
jjvw's Avatar
They will stop the flop until they wear out and stop stopping the flopping.
This is the problem with inverted T steering and why Currie with the factory geometry is the way to go.
https://youtu.be/3FbHRZbrWss
Ironhead likes this.
2003 Rubicon
jjvw is offline
post #3 of 17 Old 09-17-2019, 11:17 PM
TheBoogieman
Distubed Jeepaholic
TheBoogieman's Avatar
Try to say that 5 times really fast.
tworley likes this.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
03' Rubicon/Zone 4" coils with 1" spacers up front/Rancho shocks/5.13 gears-35" MTZs/BM brakes
99' XJ / 5.5" lift / Rancho shocks/33" DC Extreme country MTs. Jeep #18
TheBoogieman is offline
post #4 of 17 Old 09-18-2019, 09:26 AM
TJnBC
I have been using something similar for over 3 years (Ruff stuff sells them). It does what it says and has no wear on it yet. Definitely has paid for itself...
I would just contact Synergy and give them your TRE part numbers. I believe they will work no problem as Syngery uses bigger TREs in there steering kits. But verify with them first
2006 LJR...the madness begins again
TJnBC is offline
post #5 of 17 Old 09-18-2019, 10:13 AM
jjvw
jjvw's Avatar
I have this kit on my TJ. http://www.ballisticfabrication.com/...y-tie-rod-ends
I now have the nice tie rod flop going on. Found this product. http://www.synergymfg.com/synergy-je...ust-boots.html
I have been using something similar for over 3 years. It does what it says and has no wear on it yet. Definitely has paid for itself...
How many miles?
2003 Rubicon
jjvw is offline
post #6 of 17 Old 09-18-2019, 10:23 AM
TJnBC
How many miles?
I have driven with it on for approx 15,000 kms.
TJnBC is offline
post #7 of 17 Old 09-18-2019, 12:07 PM
vosevichs
They make a cure for that!
https://www.ruffstuffspecialties.com/catalog/R1768.html
Scott Vosevich
vosevichs is offline
post #8 of 17 Old 09-18-2019, 12:35 PM
TheBoogieman
Distubed Jeepaholic
I have driven with it on for approx 15,000 kms./9,320.56 miles
TJnBC likes this.
post #9 of 17 Old 09-18-2019, 12:59 PM
Ironhead
Ironhead's Avatar
Originally Posted by vosevichs View Post
theres a much better cure, stick to the inverted Y.
tworley likes this.
Ironhead is offline
post #10 of 17 Old 09-18-2019, 01:27 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Exactly, there's not much of a worse steering design to install on a TJ than an inverted-T. Bump steer, dead spot in the steering, and tie rod flop is what it is best at.
Jerry Bransford is online now
post #11 of 17 Old 09-18-2019, 01:32 PM
jjvw
jjvw's Avatar
This is a Currie "hi steer" setup. Can't do much better on stock axles.
tworley likes this.
2003 Rubicon
jjvw is offline
post #12 of 17 Old 09-18-2019, 01:37 PM
TJnBC
He already has bought a steering setup...
I have a similar inverted T setup and no issues whatsoever. TREs can be bought at ANY parts anywhere in the world for a lot cheaper than Curries proprietary TREs.
Bump steer = zero
Dead spot = zero
Tie rod roll = zero
TJnBC is offline
post #13 of 17 Old 09-18-2019, 01:53 PM
Jerry Bransford
Administrator
Of course not, I wouldn't have expected any other answer. Nope, inverted-T systems cause no problems, they're absolutely perfect and Jeep should have gone with that design for the TJ instead.
post #14 of 17 Old 09-18-2019, 02:05 PM
TJnBC
You mean to tell me that Jeep designed everything perfectly ??
Why are all the aftermarket companies still in business then?? Seems like Jeep should have ONLY made aftermarket parts as they are the experts!
Anyways OP I don't want to derail this thread. This is my experience on two jeeps and countless other TJs and XJs up here run the same setup.
TJnBC is offline
post #15 of 17 Old 09-18-2019, 04:11 PM
Kiwi_TJ
Attachment 3859079
Is this just with one of those tapered flip inserts on the tie rod to knuckle side? Was thinking of doing the same thing on my Jeep. Did you have to raise the sway bar mount tab?
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
