JeepForum.com (https://www.jeepforum.com/forum/)
-   TJ Wrangler Technical Forum (https://www.jeepforum.com/forum/f9/)
-   -   Steps to Flush Heater Core (https://www.jeepforum.com/forum/f9/steps-flush-heater-core-1256757/)
djflyy 08-24-2011 08:20 AM
10/14/2011 Edit:
If you find yourself here looking for steps on flushing a heater core, please follow this link to my step by step write up (with photos) of the process.
Hey all,
So my TJ hasn't been blowing the same temp air in the winter that it used to, and so before things start freezing up and making this "mod" one that I can't do (no garage here) I was hoping to flush the heater core out and try and see if there's any gunk in the hoses that are preventing the real heat from coming through. I've read the threads on it, but unfortunately I must admit that I'm not entirely sure what hoses I need to disco and flush.
I was hoping someone might have photos of this that they could share so that I know exactly which hoses I'm going for. Best I've been able to find is from Stu's site, the following picture.. Should I just disconnect those two from both ends and run the garden hose through it?
Thanks, all!
http://www.stu-offroad.com/engine/he.../htrcore-4.jpg
angelo2975 08-24-2011 08:30 AM
Just a bit of FYI on the flushing part
http://www.cherokeeforum.com/f2/flus...er-core-14859/
jeepinhokie 08-24-2011 08:47 AM
1 Attachment(s)
not my picture, but i circled the heater core hoses coming off of the water pump. this is where i have disconnected the hoses to flush the heater core. it gives you some hose to play with, so your not dumping antifreeze all over your firewall.
using a hose is fine, but you will want to collect the first few gallons out of the heater core b/c you are really flushing antifreeze out of the heater core. I placed a bucket in the engine bay to collect the anitfreeze. This will also allow you to tell if any debris is coming out of the heater core.
Do NOT use the hose on full blast, use a gentle flow of water and gradually increase the pressure.
if you do get a bunch of debris out of the heater core, it might be a sign that your water pump is starting to fail. at least my wifes cherokee was that way.
Please dispose of your used antifreeze properly. into the ground is not an appropriate disposal location.
JWebber 08-24-2011 08:51 AM
Th prestone flush kit is a easy thing to hook up and use. Just tap into the hot side heater core hose and turn on the water hose. But if you really want to remove crap spray a nozzle thru the return line etc.. I then blow air thru it to remove as much tap water as possible.
BamaJeepman21 10-14-2011 09:49 PM
Old thread I know but I don't want to start a new one. My heater blows hot some days and cooler others. I had the cooling system flushed back in July and apparently that should have flushed the core to. I want to flush the heater core myself but I'm reading that you have to refill with coolant? Some say it's just unplug, flush, plug while others are saying unplug, flush, dry, plug, refill. Also it doesn't matter if you unplug from the firewall or the one close to the radiator?
djflyy 10-14-2011 09:53 PM
Here's a write up I did (with photos) on flushing a heater core. Wrote it a few weeks after posting this thread!
https://www.jeepforum.com/forum/f9/he...hotos-1266369/
BamaJeepman21 10-14-2011 09:59 PM
Thank you my good man! :cheers2:
tjlemay 12-13-2013 06:47 AM
This was very helpful thank you.
Oh and I noticed that you have 35'' tires on you 99 tj lifted. Do they work well or do you find that you are rubbing to often? I have a 3'' suspension lift and I have 33'' tires, which have been pretty hard to find, so I just curious.
backyardjeeper 11-07-2014 04:47 PM
I did this last week. Worked great for a few days, then Back to no heat. Oddly enough, when it is just warming up (say around 150-170), I have lukewarm heat. When it warms all the way up to 200-210, it stops blowing warm and is just cold. I'm gonna try a complete flush, I'm afraid I had crud in other parts and it got pushed back into the nice clean core.
turpehar 11-24-2014 02:59 PM
1500 Attachment(s)
I used a mixture of white vinegar and lemon juice after flushing it with clean water. The results were unbelievable. Filled up the core with 50/50 of vinegar and lemon juice, waited 30 minutes and flushed until clear. Repeat until only clear comes out after the 50/50 mix. My heater core seemed restored to normal operations.
Cincy71 11-05-2017 02:29 PM
Since this board has been so helpful to me, I thought I would share how I finally got heat out of my 2004 Wrangler. First let me tell you what I tried. I tried flushing with a water hose through the heater hoses about a dozen times. Water coming out of the hoses was clear as could be. Did the Prestone flush kit. I let CLR soak overnight. Flushed the whole system again and added new coolant/antifreeze. The heat was still barely blowing warm. I was a day away from taking out the dash and replacing the heater core.
So I decided to try circulating CLR using a pump. I bought a 300-500 gph submersible fountain pump from lowes. Took a milk jug, cut the top off, poured the CLR in and filled the rest with water. Hooked one of the heater hoses to the pump, submerged the pump in the mixture and let the other heater hose discharged in the same jug. Circulated for about 5 hours. Then hooked up a water hose to the heater hose and flushed again. About 30 seconds into the water flushing, something broke lose in the heater core and it just poured junk out. Hooked everything back up, topped off coolant and started the Jeep back up. Heat is blasting again.
Cincy71 11-05-2017 02:42 PM
1 Attachment(s)
Adding picture. Hard to see but took a picture when the pump was circulating.
Shark_13 11-05-2017 05:03 PM
That's a cool idea!
Another member had mentioned they take a rubber mallet and lightly hit the firewall during the flushing process to help loosen the built up chunks inside.
I haven't tried it myself but I plan to next time.
The time now is 12:07 AM.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
