SSYE Install in or out of Jeep? - JeepForum.com
 1Likes
  • 1 Post By CGrugger
post #1 of 13 Old 07-05-2020, 01:35 PM Thread Starter
Kiwi_TJ
Hi Guys,
I am getting set up to install my JB Conversions SSYE. I have access to a vehicle hoist for the day. So I have two main questions:
  1. I was wondering if people have found it easier to leave it in the Jeep or take it out?
  2. Also, any idea on the average elapsed time for installing an SSYE?
I am a pretty competant mechanic, having installed my lift and done most of the maintenance on the Jeep myself. Jeep already has adjustable upper control arms.
Looking to install it in the next couple of weeks, then take the axle out and weld in the new rear trackbar bracket to accept my new track bar.
1997 TJ Soft Top/ Half Doors
4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header
31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights
Kiwi_TJ is offline
post #2 of 13 Old 07-05-2020, 01:39 PM
CGrugger
CGrugger's Avatar
Originally Posted by Kiwi_TJ View Post
Hi Guys,
I did the teraflex ultra short sye on my jeep, and I did it in the jeep, and I did it while the jeep was on the ground. So you should be fine doing it on the lift.
No idea on the time, I had one of the seals get stuck and struggled to get it out...
Sent from my Pixel 2 XL using Tapatalk
Jerry Bransford likes this.
2005 TJ X: MC 3.5" lift, 33"x12.5" tires, 1.25" Zone body lift, Curry Antirock sway bar.
CGrugger is offline
post #3 of 13 Old 07-05-2020, 03:01 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
X2, definitely keep the tcase installed which helps the job go more easily and faster. I was ready to remove my tcase 20 years ago to install a SYE but a far more experienced friend (mrblaine) came over to help and said 'nope we'll keep it installed and it'll be easier'. He was right. What we did to make the job really easy was I backed the rear of my TJ up onto a pair of car ramps and we could then do the job on our knees or sitting on our butts instead of having to lay on our backs.
Jerry Bransford is online now
post #4 of 13 Old 07-05-2020, 04:21 PM
sh00ttok1ll
In the Jeep, no question. I had the Jeep on a lift too and was surprised how quick it seemed to go. I think I had it done in a couple hours and I had no experience with it.
sh00ttok1ll is offline
post #5 of 13 Old 07-05-2020, 04:42 PM
Duck Doctor
I’ve installed three SYEs over the past 10 years. Once with the tcase in the rig and twice by removing the tcase and installing the SYE on a work bench.
If you don’t have a lift then I recommend removing the tcase from your rig for the install. The tcase is light and can be easily removed from your rig and reinstalled without the need for a jack. Make sure you buy a 9/16” ratcheting wrench to separate the tcase from the transmission. Might as well install a cable shifter too since the shifter linkage will be removed.
My last SYE install took three hours from start to finish. I am 6’3” so removing the transfer case and reinstalling is a simple task.
The process would be much more time consuming if you require a jack to remove/install the tcase.
Duck Doctor is offline
post #6 of 13 Old 07-05-2020, 04:49 PM
Stumptown
I took mine out. But I am one of those crazy people who like to clean everything when I am working on it. With it out, I was able to scrub the case clean.
Pulling the case probably adds about an hour to the process. Scrubbing the case added a bunch more time.
Easy process, but make sure you have the proper set of snap ring pliers. A set of internal snap ring pliers and flat nose ring pliers. The snap rings are the worst part of the job.
And no lift needed for the job. A floor jack will be okay if you choose to remove the case.
Stumptown is offline
post #7 of 13 Old 07-05-2020, 06:02 PM
Jerry Bransford
Administrator
It stayed clean until the next regular Oregon rainstorm.
post #8 of 13 Old 07-05-2020, 07:01 PM
rikkards
rikkards's Avatar
The hard part is getting the retaining clips off especially if you don't have the right tools, that is irrelevant on if it is mounted or not.
Personally I did it with it installed
Machete don't tweet
- Machete
rikkards is offline
post #9 of 13 Old 07-06-2020, 02:05 PM
ffej
I'm not familiar with the manual transmission to t-case mounting, but is there a seal in the adapter like there is in the auto-equipped TJs? I had to replace the seal in my auto-equipped TJ which developed a slow drip at the seal. Replacing it required pulling the t-case.
ffej is offline
post #10 of 13 Old 07-06-2020, 10:26 PM
GermanyChris
I took mine out
I'm generally a very pragmatic person: that which works, works. -- Linus Torvalds
GermanyChris is offline
post #11 of 13 Old 07-07-2020, 08:23 AM
LumberjackLloyd
I took mine out as I had a slightly leak at the output of the transmission; it is very easy to take out. I have also installed SYE's while still in the Jeep when there were no issues seen.
I recommend these pliers.
https://www.amazon.com/Stanley-Proto...s%2C134&sr=8-8
LumberjackLloyd is offline
post #12 of 13 Old 07-07-2020, 09:07 AM
tworley
tworley's Avatar
Left mine in. I had no trouble installing it.
Colorado Member 307
tworley is offline
post #13 of 13 Old 07-07-2020, 08:23 PM Thread Starter
Kiwi_TJ
It it is then!
Hi Jerry,
Thanks for that, sound good enough for me. Since my friend has a two post vehicle hoist, so that I can have it all at a good working height, sounds like the best way to go. He also owns a set of those flash flat clip ring pliers that I will need.
From what others have said, it sounds like it will take 2-4 hours depending on how things come apart, which is good, so I should be able to finish it up in day. That is good as the Jeep is my only transport, so once it is in bits, I am committed until it is running again.
Kiwi_TJ is offline
