Spider Gears and Cost... - JeepForum.com
post #1 of 16 Old 04-11-2007, 09:16 AM Thread Starter
gjcojeep
Guest
I have been quoted $500 to replace the spider gears in my rear end.
Is this reasonable or too much?
It is only the spider gears, no bearings or anything. Just the spider gears. Thanks!
gjcojeep is offline
post #2 of 16 Old 04-11-2007, 09:20 AM
JeepinYahoo
JeepinYahoo's Avatar
1977 CJ5
It should be really easy and that would not be a good price. You do not need to remove the carrier or anything to get them out so you could do it yourself. One problem might be if you have really low gears. In front there is no way of removing the crosspin from the carrier because the gears are in the way. So, when I bust my front spiders, I can't fix it myself and it will cost a lot. And I can't put in a lunchbox locker either.
'77 CJ-5---'63 Scout 80 FOR SALE---'71 Scout 800B---'78 F-250 Camper Special---'75 Econoline 100
JeepinYahoo is offline
post #3 of 16 Old 04-11-2007, 09:22 AM Thread Starter
gjcojeep
Guest
he didnt go into details about what he is having to do to replace them but I am pretty ignorant on what needs to be done.
The problem I have is I trust this guy but if he is ripping me off, I want to know. What are some questions I should ask to see what all he is doing?
gjcojeep is offline
post #4 of 16 Old 04-11-2007, 09:24 AM
87Xota
Guest
That's pretty high if it truely is just the spiders, it's maybe at most a 2 hour job. But if they are including the price of new from Jeep spider gears, maybe not that high of a price.
I would suggest you post up asking for a set of used spider gears, just about everyone who's installed an ARB or Detroit has there old carrier and spider gears left over. And spider gears don't wear much, they are only in use when turning corners or when one wheel is slipping, they last forever if they don't get broken on the trails.
87Xota is offline
post #5 of 16 Old 04-11-2007, 09:26 AM
JeepinYahoo
1977 CJ5
It would be a little expensive IMO. I blew the spiders in my rear dana35 when it was stock, assuming your axle gears are stock or close to it, there should be no trouble with getting the crosspin out. I wouldn't imagine it would take a shop more than 2 hours. Figuring parts are cheap, maybe $150 and it shouldn't take long, at $95 per hour that is wtill only $350 for the job. Personally, I could do it in my driveway with hand tools in about an hour to an hour and a half. I find it hard to imagine that a shop with proper tools and whatnot would need even longer.
post #6 of 16 Old 04-11-2007, 10:25 AM
stoker
Guest
This isn't a problem, It's an oppotunity for an upgrade. Forget the spiders. Put in a LL or an LS.
The problem will be fixed and your Jeep will be better for it.
stoker is offline
post #7 of 16 Old 04-11-2007, 10:29 AM
chutta
pay him his estimate fee and do it yourself, there's plenty of help here on the forum and you're going to have to get self reliant or go broke with a Jeep
chutta is offline
post #8 of 16 Old 04-11-2007, 10:34 AM
bobbert350
bobbert350's Avatar
wow thats a ton of money for that you could get the rear regeared and all new guts for a 150 bucks more...id say do it yourself if you have any mechanical knowledge...the hardest part should be the backlash on the ring gear...i could help you if you like just pm me i have no classes mwf...just pm me and i can maby take a trip to where you are your not far
88 jeep wrangler, 4.2, auto---cragar soft 8's, d35 locker, bucket seats with 5 point harnesses, warn bumper w/ grill gaurd, winch plate, kc daylighters, light bar, herc the interrior, rebuilt tranny (yay) with tranny cooler, winch and msd ignition, 3.5 inch fabtech lift, currie boomerang shackles f/r, weber carb...[B]
Why only go anywere fast when you can go anywhere
bobbert350 is offline
post #9 of 16 Old 04-11-2007, 10:39 AM
JeepinYahoo
1977 CJ5
You can remove the spiders without removing the carrier so backlash is not an issue. Unless you have my gears up front which do not allow the crosspin to be removed without the ring gear off of the carrier.
post #10 of 16 Old 04-11-2007, 10:41 AM
kloppk
kloppk's Avatar
That's a very high price in my book.
You can buy the kit to replace them for under $100.
You can do it yourself with basic hand tools, a couple of quarts of 75W90 and some RTV silcone.
Should take under 2 hours of your time tops.
Save yourself $400 and DIY!
kloppk is offline
post #11 of 16 Old 04-11-2007, 10:42 AM
Dogman
Dogman's Avatar
That is way high. Even the labor to install a new ring & pinion should only be about $300.
John 3:17
Dogman is offline
post #12 of 16 Old 04-11-2007, 10:43 AM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
I just did this last weekend on my D35. (yj). $6.00 for spiders from the local boneyard, 2 hours to pull the old ones and add the new ones in.
Go this route, it's rather easy.
Pull wheels. Unbolt axleplate and slide axles out about 4 inches.
Remove diff cover, then remove 4 bolts holding carrier in place.
With Carrier on workbench, remove roll pin and spiders rotate right out. Rotate in new spiders. Installation is reverse of the above.
Wven with only basic hand tools this is less than a 2 hour job in the driveway or garage.
- Ernie
Richmond88yj is offline
post #13 of 16 Old 04-11-2007, 07:22 PM
bobbert350
bobbert350's Avatar
i bet he can do it even easier than we can i thought on the c-clip d35 there was a nut that holds the pinion shaft in on ours we have to hammer that stupid shear pin or whatever its call..i could be wrong about this just from what i was told
post #14 of 16 Old 02-07-2017, 09:10 AM
mowardhome
I have the same question about the spider gear. The repair shop wants to replace all the gearing - front and back. Their claim is that the TJ has 323 gears which are hard to find. They want to put in 373 gears just to fix the missing teeth in the spider rear. I know that I would like more power in the 327, but do not need to spend unnecessary money on the toy. Can the missing teeth be repaired without replacing gears?
mowardhome is offline
post #15 of 16 Old 02-08-2017, 09:03 AM
joe_jeep
U cant fix missing teeth.
if you have a jeep tj, its not 3.23 gears.
Its 3.07, 3.55, 3.73, 4.10, or 4.56.
u might seek a second opinion at this point.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
Removing side gears and spider gears... Mudbug1979 TJ Wrangler Technical Forum 2 10-08-2009 06:34 AM
cant get spider gears out neverbackdown TJ Wrangler Technical Forum 5 06-29-2008 08:17 PM
Can u put spider gears dana 30 with out resetting the gears? magnum629 TJ Wrangler Technical Forum 2 02-19-2007 09:55 AM
spider gears 1993yj YJ Wrangler Technical Forum 2 01-20-2006 08:44 AM
Spider Gears jeems YJ Wrangler Technical Forum 1 10-02-2005 09:53 PM
